Author Topic: [Theme] Do you have a stitched photo?  (Read 220925 times)
Re: [Theme] Do you have a stitched photo?
« Reply #270 on: June 02, 2017, 05:23:15 »
Thanks, Hugh!
At first, I took a single frame covering only the centeral area of this pano posted here:
http://nikongear.net/revival/index.php/topic,2816.255.html
Then I tried to make a pano for wider coverage of this impressive cloud, despite of my past experience of Photomerge failing to stitch the flare correctly.  The result was way more pleasing than I had expected.  :)
« Reply #271 on: June 04, 2017, 01:43:55 »
June 04, Morning. D750, AF-S 50/1.8G.  10 vertical images are stitched for 180+ degree coverage.
I accidentally switched the camera to suto ISO mode, and shot the frames with the fixed shutter speed and aperture.  The ISO values ranged from 180 to 220 throughout the frames.  I think I was helped by the rather even brightness and the wide dynamic range of D750.   8)
« Reply #272 on: June 04, 2017, 08:53:03 »
Good one, Akira.  Here's one with 5 horizontally oriented 50mm shots, shot using tripod. The location is a crossroads in the lonely desert 'town' of Niland, California, which sits near the Salton Sea:
« Reply #273 on: June 05, 2017, 07:08:23 »
Thanks, Keith.  The perspective of your pano looks very natural.  I like the overall atmosphere.
« Reply #274 on: June 05, 2017, 15:24:14 »
You are blessed with a beautiful sky and gorgeous clouds, Akira. Keep sharing them :)
Clean and nice shot, Keith. Lonesome town indeed.
« Reply #275 on: June 05, 2017, 16:33:39 »
Anirban, thanks for the comment!  Yes, I have quite a few opportunities to see some impressive skies and clouds.  I'm a bit concerned about the climate change, though, considering that the clouds are visual representation of the turbulence of the air...
« Reply #276 on: June 05, 2017, 16:41:41 »
North of  Guadalajara Mexico
8 vertical shots with the 20mm lens
« Reply #277 on: June 05, 2017, 16:45:56 »
Armando, again, this pano looks very natural to me.  Maybe more natural than a single shot with the 20mm.
« Reply #278 on: June 05, 2017, 16:53:54 »
Akira - I agree.  Armando, this pano looks great - well done.
« Reply #279 on: June 05, 2017, 17:43:16 »
Thanks !! Glad you like it
Shooting a pano with the 20mm with such immense distance is not a problem
« Reply #280 on: June 05, 2017, 19:51:03 »
.. I'm a bit concerned about the climate change, though, considering that the clouds are visual representation of the turbulence of the air...
Very true Akira.
« Reply #281 on: June 21, 2017, 13:09:12 »
After the stormy rain.  D750, 50/1.8G.  8-stitch pano.
Danulon
« Reply #282 on: June 21, 2017, 21:43:57 »
Anaga Mountains on Tenerife/ Canaries,
February 14th 2017
D750 + Zeiss 35 mm 2.0 ZF.2 @ f/8.0
13 vertical shots, handheld
Stitched in Lightroom CC
Guenther Something
Danulon
« Reply #283 on: June 21, 2017, 21:54:16 »
Glencoe area (--> Dave?), Scotland
May 13th, 2016
D750 + Zeiss 25 mm 2.8 @ f/8.0
about 3 horizontal shots, handheld
stitched in Lightroom CC
Guenther Something
« Reply #284 on: June 26, 2017, 21:50:11 »
double fish
