Author Topic: [Theme] Do you have a stitched photo?  (Read 220495 times)
Re: [Theme] Do you have a stitched photo?
« Reply #195 on: August 19, 2016, 11:27:31 »
Congratulations John!
Be sure to take a photo of the flag once it's up :)
« Reply #196 on: August 19, 2016, 11:51:47 »
Thanks Jakov. I will.
The flag will contain other photo's as well, like this one....
« Reply #197 on: August 24, 2016, 04:45:36 »
I post panos fairly regularly here in NG, but this is the first one in a while to post to this particular thread.
If the cloud visualize the turbulence of the air, the situation should be quite complicated.   ::)
« Reply #198 on: August 24, 2016, 19:31:29 »
Mr Cloud strikes again :)
« Reply #199 on: August 25, 2016, 00:22:52 »
That is a great overview, Akira. And very wide, did you use many photo's?
« Reply #200 on: August 25, 2016, 00:27:32 »
Thanks, Jakov.  Recent years we have various interesting clouds here in Tokyo.  That proves that the climate is unstable, so it is mixed blessing...
Thanks, John.  I used 12 images in portrait orientation to stitch this pano whose horizontal coverage is nearly 170 degree.
« Reply #201 on: August 29, 2016, 07:13:15 »
At the Turtle Mountains, southeastern California.  4 horizontal frames w/ 28mm.  Open in separate window for better viewing.
« Reply #202 on: August 29, 2016, 09:09:22 »
Keith, you were blessed with the beautiful scenery in the first place for this amazing pano.  Did you handhold the camera?
Les Olson
« Reply #203 on: August 29, 2016, 09:17:09 »
The Chateau d'Yvoire (built in 1306, but largely destroyed by the Genevois in 1592, and converted into a house in the 20th century) on its promontory, and Lac Leman.   Four film frames stitched in Photoshop Elements.  Nikon 85mm f/1.8G, Ilford FP4 scanned on an Epson V600, grain boosted.
« Reply #204 on: August 29, 2016, 10:27:05 »
Handheld, about 1/3 overlap.
« Reply #205 on: August 29, 2016, 10:38:09 »
Great overview Keith.
Unusual overview Les. Large scans? It's a bit contrasty I think.
« Reply #206 on: August 29, 2016, 10:52:23 »
Thanks!  Did you try to pan around the position of the entrance pupil even roughly?
« Reply #207 on: August 29, 2016, 11:38:14 »
Overview Stadhuisplein after demolition
Df - Angenieux 35-70/2.5 - 9 portrait-mode photostitch
Best advice on the stitching process
« Reply #208 on: August 29, 2016, 11:49:23 »
I may have missed it earlier in this thread, but would anyone care to share some of the points that turn a good stitched set of images into a great one?
For example, what are the upsides and downsides of doing/not doing this?
And does it depend on the focal length used, software & any included optimisation etc?
Re: Best advice on the stitching process
« Reply #209 on: August 29, 2016, 11:57:18 »
For example, what are the upsides and downsides of doing/not doing this? [rotating around the entrance pupil]
First and foremost, successful stitching depends on components of the scene being static and how much geometric error the images contribute, and worst of these are parallax errors when part(s) of the overall scene is close to the camera. in the latter case, rotating around the entrance pupil position is highly recommended.
Do note here I only talk about the technical outcome of the stitching process. Whether the final result works as a successful photograph has little to do with the underlying technique and stitching is no exception.
