Author Topic: [Theme] Do you have a stitched photo?  (Read 219861 times)
Re: [Theme] Do you have a stitched photo?
« Reply #165 on: August 08, 2016, 07:25:44 »
Matthew - clearly thats the way to go if one looks at your results. Good image.
But then I look at the iphone pano and want to scream with frustration that nikon cant do that.
Harald
    • Flickr
« Reply #166 on: August 08, 2016, 09:19:40 »
Some pictures on FLICKR
Les Olson
« Reply #167 on: August 08, 2016, 11:46:25 »
The Saone at Lyon.  Nikon V1, 18.5/1.8, four images stitched in Photomerge in Photoshop Elements 11.
Matthew Currie
« Reply #168 on: August 08, 2016, 16:08:07 »
I believe the D3300 does have a panorama mode.  I don't know how well it works, but it sounds from what I've read that it still has some problems.  I have a little Fuji XP-60 pocket camera that does panoramas, and the results are not bad, but it requires a pretty steady hand.  There's a menu choice of width, and if you don't get a pretty fair percentage, it stops with no image.
« Reply #169 on: August 11, 2016, 10:04:57 »
A stitch is not always a panorama  ;)
9 photostitch
« Reply #170 on: August 11, 2016, 10:29:17 »
John, this is intriguing!  Is the bokeh background also stitched?!
« Reply #171 on: August 11, 2016, 10:36:49 »
Thanks Akira.  Yes. I took the main subject as Photo 1 and the other 8 are the 'surroundings'.    It's called the 'Brenizer Method' and creates an extra shallow of depth.
 In fact it gives the 85mm  f/1.4 lens (which I used here) a kind of  45mm f/0.8 lens.  According to a calculation on this site.    http://brettmaxwellphoto.com/Brenizer-Method-Calculation/
« Reply #172 on: August 11, 2016, 11:08:42 »
Thanks, John, for the link of the method that is totally new to me.
« Reply #173 on: August 11, 2016, 11:15:33 »
John, that is a rather revolutionary concept :)
Although, if I have to nit pick, the background is not as creamy as it should be with the 85/1.4 :)
« Reply #174 on: August 11, 2016, 11:21:32 »
Yes, true. That is due to the larger distance. A disadvantage of the method.   ;)             I should have moved closer  (which was here impossible due to a number of obstacles).   There is always room for improvement.
« Reply #175 on: August 11, 2016, 11:51:51 »
It is yet another interesting way to deal with stitching technique
My current favourite is still the multi focus:
You create a set of extremly shallow DOF shots and bring two
different levels to focus/interest, leaving the space inbetween
blurred. I first saw that 12 years ago done by Willem van den
Hoed which got me investigating further into that. You can stitch
these by hand or use some advanced features of specialized
software like Kolor Autopano.
« Reply #176 on: August 11, 2016, 14:37:26 »
Hey. Funny. I know this guy. He was one of my first Flickr
Buddies before his wedding business in NYC took off.
Very nice guy. Everybody can learn from his work.
« Reply #177 on: August 11, 2016, 19:05:47 »
Especially for Jakov --  More bokeh !
This time a 15 photo stitch (but more overlaps between them), nearly the same position, different lens ;)
« Reply #178 on: August 11, 2016, 19:37:08 »
Thanks, John! This one rocks  :)
« Reply #179 on: August 11, 2016, 19:59:08 »
Yes, Ryan Brenizer is the one who gave his name for this kind of stitching.  https://en.wikipedia.org/wiki/Brenizer_Method
