Author Topic: Nikkor 28mm f/3.5 AI disassembly guide  (Read 87 times)
whatdoido
  • You ARE NikonGear'23
« on: April 16, 2026, 23:43:20 »
https://whatdoineed2do.blogspot.com/2026/04/an-economical-wide-alternative-28mm-f35.html#servicing
A fairly easy lens to service.  Surprisingly sharp wide open in the near range and running my 28mm f/2.8 AIS very close!
Slightly different construction to the AI-S variant which Ric has covered here:
Nasos Kosmas
  • Athens, Greece
Re: Nikkor 28mm f/3.5 AI disassembly guide
« Reply #1 on: Today at 13:48:11 »
Nice work :)
I still got this lens, my second nikon lens after 50 mm 1.8 , early 80’s
It was lower priced than the 2.8 version so it was preferred 8)
I did some testing with the f 2.8  on BW film these days and found no difference -as you already mentioned-the same excellent Nikon contrast :)
Now days I’ve got 28/2.8 z lens but used only once
