Author Topic: Using Neweer NW-ETZ to get focus confirmation and correct IBIS  (Read 2978 times)
Snoogly
  • Flipping the bird
Re: Using Neweer NW-ETZ to get focus confirmation and correct IBIS
« Reply #15 on: May 05, 2026, 03:10:33 »
It confuses me because aperture would be set on the lens, with a Z camera just metering based on what it sees.
Could this be only be applicable if one also sets the aperture on the camera for accurate shooting aperture in exif?
« Reply #16 on: May 05, 2026, 05:32:42 »
Yes, this is also what is confusing me.
Hopefully once these adapters start getting delivered, we can then figure out just how one sets the desired taking aperture and get it to be correctly recorded in the EXIF data and achieve the correct exposure.  I do dream somewhat ....
Jürgen Pfeiffer
  • You ARE NikonGear'23
« Reply #17 on: May 05, 2026, 12:31:12 »
Yes, but this doesn’t seem to be a problem exclusive to the Shoten adapter; it also appears to affect the Neweer and Funmount adapters.
It probably has something to do with how the aperture behaves on Nikkor Z lenses (and manual-focus Nikkor lenses fitted with Dandelion): from f/1 to f/5.6, the aperture blades close in line with the setting on the camera’s control dial. If a smaller aperture is set on the camera, the aperture blades on the lens stay at 5.6 and only close at the very moment the shutter is released.
As Richard has already suspected, the problem with the Neweer/Funmount/Shoten adapters only occurs when an aperture smaller than f/5.6 is set on both the camera and the lens. The camera seems to think that, with an aperture of 11 set on the body, the size of the blades corresponds to an aperture of 5.6 on the lens (with manual lenses, however, the aperture does indeed close to the value of 11).
With these adapters, it is therefore no problem to shoot from wide open to f/5.6 AND to set the corresponding value on the camera’s control dial for correct EXIF data.
Photographing with apertures from f/6.3 down to the smallest aperture is also no problem, as long as the control dial remains set to a maximum of f/5.6 (the EXIF entry is then no longer correct, but I suppose you have to live with that).
Side note: with the Voigtländer lenses for Nikon Z, everything works as it should; however, the camera’s control dial has no function there either.
Jürgen Pfeiffer
Snoogly
  • Flipping the bird
« Reply #18 on: May 05, 2026, 22:25:38 »
I wish Shoten would replace their ‘explanation’ with yours!  :)
True, but on some (sadly not all) Z camera bodies, one can record voice clips where the photographer can verbally record what settings he/she is using for a particular shot.  Clunky I agree, but better than nothing.
Jürgen Pfeiffer
There are other methods to ensure that the correct aperture is displayed in the EXIF data. Beforehand, you should set the view mode to “Adjust for ease of viewing” in the camera’s custom settings, so that the viewfinder maintains a consistent brightness.
The methods, listed in order of increasing “clunkiness”.
Not too clunky:
Set the exposure compensation to -1 at f/8, to -2 at f/11 and to -3 at f/16 (nobody shoots at f/22 unless they have a large-format camera).
Quite clunky:
Set the camera to M shooting mode and meter the exposure at f/5.6. Then double the shutter speed at f/8, quadruple it at f/11 – you get the idea…
Definitely clunky and very old school:
see illustration
Jürgen Pfeiffer
