Author Topic: Using Neweer NW-ETZ to get focus confirmation and correct IBIS  (Read 3429 times)
Snoogly
  • Flipping the bird
This seemed a rather nerdy thing to do, but it might be of interest to others. It enables me to get focus confirmation and correct IBIS info for any of my manual F mount lenses, and I just need to use my ancient iPhone to ‘edit’ the text file containing the connected lens’s data.
Connected NW-ETZ to my Mac and copied the lens text file to the Mac. Made several copies and edited them to match some of my Nikon F mount manual lenses. I don’t think you should rename the text file, so I placed each one in a lens-named folder. Then easy to copy a chosen text file to the adapter, opting to ‘replace’ the existing file. Works a treat, and the lens exhibits correct exit data on my ZF, I get the green light (and the traffic lights), and IBIS is correct.
So far it’s not exciting, as many have done this already. But I wanted to be able to do this on the fly without a Mac. So I connected a lightning ‘camera’ dongle to my iPhone 13 mini. This has a USB A socket and USB 3 for power input. I used my smallest USB power bank for power. Then I connected the Neweer USB cable and popped it on the adapter. On the iPhone I navigated to the set of folders where I had saved text files for my F mount lenses (files saved in my Dropbox). Selected a text file and then ‘shared’ to the ‘Files’ app and then on to the connected Neweer adapter. Again chose to ‘replace’ the existing file.
Bob’s yer uncle, it worked, and only took about three minutes. No need for any file editing out in the field, just dropped an existing text file on to the adapter.
I did this with Nikon F lenses, via an F to Sony adapter, but of course it would also work with other types of manual lenses with an appropriate adapter.
Re: Using Neweer NW-ETZ to get focus confirmation and correct IBIS
« Reply #1 on: March 21, 2026, 22:38:58 »
Nice work Richard.
Am I correct in guessing that this combination of adapters will also correctly enable the Nikon image stabilisation features as well as the green focus indicator?
Snoogly
  • Flipping the bird
« Reply #2 on: March 21, 2026, 22:49:33 »
I think so, and the word on the streets is that the text file does tell the camera the correct IBIS setting, but until I see evidence it doesn’t I can’t be sure!
But online info is sometimes wrong .. By all accounts it should be possible to edit the text file directly on the adapter, but I tried that and it would not save. However, I think it is more practical to create a bank of edited text files (stored in something like Dropbox), then it is easy to access them from any device, including mobile.
Jürgen Pfeiffer
  • You ARE NikonGear'23
« Reply #3 on: March 22, 2026, 13:49:58 »
Richard,
That’s a handy and very portable way to edit the text file. Very impressive!
Having a customised text file for each lens is very handy. When I edited the text file directly on the adapter, I sometimes had problems and it only worked the second time round. It seems to work best if you open the file in TextEdit, edit it, and then simply close it with ⌘W.
I can confirm that the adapter supports IBIS; you can try it out yourself, for example by entering a focal length of 200mm in the text file for a 50mm lens. The viewfinder image then becomes very shaky, as the camera thinks it needs to compensate for a telephoto lens.
I’ve personally switched to treating every lens I want to use with a Z-mount camera to its own ETZ adapter. It’s incredibly handy – no more fiddling about with changing adapters; if necessary, the simple E-to-Z adapters can be precisely adjusted to the respective lens using shims.
I’ve created a small table in this post:
https://nikongear.net/revival/index.php?topic=11247.msg214971#new
 showing the different behaviour of IBIS and focus confirmation with various adapters on a Zf.
Jürgen Pfeiffer
Snoogly
  • Flipping the bird
« Reply #4 on: March 23, 2026, 04:01:35 »
Yikes! Must have cost a packet! But I can understand why you did it at such scale.
One way of looking at it is that several of theses adapters are still cheaper than a single new Voigtlander Z lens, which may only be a tad ‘better’ than one of your F lenses.
This is really like a modern day dandelion chip, in a way …
PS, do you want to sell me one of your many Neweer USB cables? I worry I may damage mine if it gets a lot of use.
Jürgen Pfeiffer
« Reply #5 on: March 23, 2026, 11:48:46 »
Richard,
Exactly, those were my reasons for fitting all my F-Nikkor lenses with an adapter, just as you say.
I don’t have Neweer adapters, but ones from Funmount; they seem to be identical in construction, and on AliExpress they cost around 100 euros each.
The cable also looks like the Neweer one, and I’d be happy to send you one; the postage from Germany to Japan is about 15 euros, and the cable won’t cost you anything. If you’re interested, just send me a PM.
‘Modern Dandelion’ – every one of my Nikkors was fitted with a Dandelion, but unfortunately the IBIS doesn’t work with it; the fact that I now have to (or am allowed to) adjust the aperture on the lens is more of an additional feature than a limitation.
Jürgen Pfeiffer
« Reply #6 on: March 24, 2026, 11:10:44 »
Where is your reliable source to buy these adapters?
Richard,
Jürgen Pfeiffer
« Reply #7 on: March 24, 2026, 11:29:33 »
Hallo Frank,
I bought the Funmount ETZ adapters via AliExpress. No problems, better order no more than one at a time, it keeps the customs procedure simpler. When it came to the AI-to-NEX adapters, I chose one that looked as understated as possible and was not expensive.
Jürgen Pfeiffer
« Reply #8 on: March 24, 2026, 12:26:55 »
In a similar approach, NG supporter Jan Anne used Fringer Canon EOS to Z  adapters for lenses with native Canon EOS mounts and also his Nikon 50mm f/1.2 lens with a chipped Nikon F to Canon EOS adapter:  https://nikongear.net/revival/index.php?topic=9130.msg173121#msg173121
Snoogly
  • Flipping the bird
« Reply #9 on: May 04, 2026, 05:02:58 »
A new kid on the block, in terms of chipped adapters. Shoten.
A slew of new adapters, virtually anything > Nikon Z. The adapters are chipped, so get green box focus confirmation & traffic lights. Also, the firmware text file can be written with up to 10 different lens profiles.
Though not quite up to Rayqual standards, I have always found Shoten adapters to be solidly made and reliable. It’s a quasi Japanese brand, though manufacturing seems to be done in China. The included USB cable is straight-outa-China, for sure. But here in Japan it is more attractive than the pure Chinese brands as there is at least some chance of local support. Also, the price! One gets a chipped lens mount with an included a Z adapter for considerably less than just a Sony > Z chipped adapter.
https://www.stkb.jp/shopdetail/000000002434/ct1276/page1/recommend/
https://www.amazon.co.jp/dp/B0GTLZGH67?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Jürgen Pfeiffer
« Reply #10 on: May 04, 2026, 13:31:55 »
Hi Richard,
That sounds promising. Apparently you can select the lens profiles by taking a shot at a specific aperture – let’s see how practical that is. But even if you use a dedicated adapter for each lens, the Shoten solution seems to be cheaper than the Neweer/Funmount option. Nikon F to Z adapters seem to be sold out at the moment, so I’ve ordered an M42 to Z adapter for my Zeiss Jena lenses. I’m really looking forward to it. I like the look of the Shoten adapters; they match the aperture ring on the old Nikkor lenses perfectly.
Jürgen Pfeiffer
« Reply #11 on: May 04, 2026, 13:43:20 »
Thanks Richard.
I am not too sure of how the lens aperture is to be accurately set with this adapter.
This link has some usage information:  https://www.aliexpress.com/i/1005011921899971.html
Snoogly
  • Flipping the bird
« Reply #12 on: May 04, 2026, 22:09:21 »
Blimey, about ¥3000 more on aliexpress than directly from Shoten here in Japan!
I can’t get my head around this part of the instructions. Can anyone unfathom it?
« Reply #13 on: May 05, 2026, 00:26:05 »
A lot of the candidate lenses for this adapter have non-linear apertures ....
I've ordered one for potential use with 1-2 non-CPU enabled F-mount lenses. Should arrive later this months if international transportation still functions.
« Reply #14 on: May 05, 2026, 02:54:40 »
Will someone correct me if I'm wrong: I believe this instruction applies to AI and earlier Nikkor lenses while not applying to AIS and later Nikkor lenses. I should know. Perchance the AIS Nikkors had linear apertures for the Nikon FA's exposure system?
