Author Topic: June 2025  (Read 15795 times)
Re: June 2025
« Reply #210 on: June 22, 2025, 01:06:27 »
Birna coach me in that very same thing. We used a little bit of toothpick to hold the lever for the aperture.
  Z9, 10.5mm in fx mode
  In this thread:... https://nikongear.net/revival/index.php?topic=11155.45https://nikongear.net/revival/index.php?topic=11155.45https://nikongear.net/revival/index.php?topic=11155.45
Hans_S
  • Melbourne, Australia
Re: June 2025
« Reply #211 on: June 22, 2025, 01:23:15 »
Photo Competitions: My wife judging Erik Kessel's entry.  "24 Hours in Photos" Erik Kessel 2011
Hans Schepers
  • Fairbanks, Alaska
Re: June 2025
« Reply #212 on: June 22, 2025, 06:23:04 »
Nice to be reminded about that creative thread. I must say I am a little nervous about jamming tooth picks and other objects inside the cavity shared with the shutter shield and sensor, although I have done the same in the past for testing purposes using a tiny longitudinal cut piece of Tygon tubing. Also taping the contacts is also a bit cumbersome. So I did a little search and found the following post with a simple solution: https://www.dpreview.com/forums/post/63688978:
1. Simply mount the 10.5mm and FTZ adapter normally without any modification.
2. Set aperture as intended. If set aperture is narrower than 5.6 activate and keep pressing the button that has been configured for depth of field preview.
3. Then immediately press lens release button on the body and twist the FTZ adapter just a smidge until F-- shows at the top display. The body will now be in FX mode with the lens remaining at the last activated aperture and body will see the lens as fully manual.
(It would now be possible to tape the contacts on the body side of the FTZ adapter if one wanted to be able to mount it locked in place with last set aperture remaining.)
This is the same trick I use with my 500PF when using it with my astrocamera. The FTZ adapter acts similar to an E-lens (or Z lens) when disconnecting without powering down the body. This is against Nikon's instructions for dismounting procedure but with DSLRs I always forgot to turn body off before dismounting lens. (With Z8/Z9 it of course is best to normally follow instructions so that the shield is activated.)
Re: June 2025
« Reply #213 on: June 22, 2025, 09:28:46 »
An unstitched version.
kasperbergholt
Re: June 2025
« Reply #214 on: June 22, 2025, 12:21:05 »
1838 edition of Flora Excursoria Hafniensis (source).
Nikon D4 & Carl Zeiss Milvus 50mm f/2.
-- Kasper Bergholt
Re: June 2025
« Reply #215 on: June 22, 2025, 13:19:38 »
Vintage look
aerobat
Re: June 2025
« Reply #216 on: June 22, 2025, 14:58:50 »
Mountain time trial Tour de Suisse 2025 - Zf & 35mm f/1.8 S
Daniel Diggelmann
Re: June 2025
« Reply #217 on: June 22, 2025, 15:37:53 »
Troubled times. We need a bridge over troubled waters.
Re: June 2025
« Reply #218 on: June 22, 2025, 16:28:29 »
with all the world suffering from the heat my little ecosystem thrives with earthworm power and agglomerate water storage in the soil
Re: June 2025
« Reply #219 on: June 22, 2025, 18:00:32 »
Vintage look
Also shot from the hip ? Awesome image
wow! should have a sign saying "handle with extreme care"
Immediatley recognizable as one of yours!
so many questions about this image
The fisheye made for some serious fun.
Almost ready...
  D5, 10.5mm 2.8 dx, shaved and shooting in Fx mode. Falla theater, Cádiz
Great image! Love the scale of the theater, composing wth a fisheye can be challenging.
Dragonfly - Zf & Z 105mm MC
Superb !
Re: June 2025
« Reply #220 on: June 22, 2025, 18:05:56 »
You nailed it there, Colin. Excellent.Probably back-breaking vantage point as well :(
Thanks Birna, I consider you an authority in many areas so feel quite pleased with your kind words
Actually, my knees hurt more than my back (bare knees on rough stoney ground)
The flip out viewfinder and D500's old-fashioned Live View made the job feasible
Ian Watson
Re: June 2025
« Reply #221 on: June 22, 2025, 21:31:30 »
The snake or the crunched toad? I have the Z 24-70/4 and I agree it's definitely very good for close-up as well
The crunched toad is the better example but the snake was quite close too.
Ian Watson
Re: June 2025
« Reply #222 on: June 22, 2025, 21:32:08 »
A pensive walk in nature.
Nikon Zf, 24-70/4S
Re: June 2025
« Reply #223 on: June 22, 2025, 21:53:37 »
Who is the rider Daniel
Re: June 2025
« Reply #224 on: June 22, 2025, 21:54:17 »
Superb !
Thank you Armando
