Author Topic: March 2025  (Read 127062 times)
Re: March 2025
« Reply #165 on: March 16, 2025, 18:39:28 »
The song "One misty moisty morning ...." comes to mind.
aerobat
Re: March 2025
« Reply #166 on: March 16, 2025, 19:58:57 »
It works in that sequence since the TC is F-mount. Unfortunately, Nikon has severely limited the options for using the TC14Z, thus you cannot simply add this TC to any Z-mount lens which fits. Or to the FTZ since the latter physically blocks the TC14Z. A pity as the Z-version of the 1.4X is really good. It works wonders on the 70-180/2.8Z and the 400/4.5Z.
Thanks for sharing your experience with the 70-180/2.8 and TC14Z.
Daniel Diggelmann
Re: March 2025
« Reply #167 on: March 16, 2025, 20:02:11 »
March 16
Mahonia
Zf  Voigtländer 40mm f/1.2
aerobat
Re: March 2025
« Reply #168 on: March 16, 2025, 20:51:30 »
The lens is a dream come true!
Because I have the 4/300PF and the 14E3 I skipped this one. As soon as I got too much money I will buy a Z9 & the Z4.5/400S ...
I've got this combination of 300mm PF and TC14E - the PF is handy to carry in the mountains where a larger lens is just too much
Daniel Diggelmann
Re: March 2025
« Reply #169 on: March 16, 2025, 21:00:57 »
Ultra-Micro-Nikkor 28mm f/1.8 on one of my modified Nikon 1V1 bodies.
Superb clarity, 3D feel and clean natural colours Birna
Jürgen Pfeiffer
  • You ARE NikonGear'23
Re: March 2025
« Reply #170 on: March 16, 2025, 21:59:23 »
Misty and cold today...
Z8 & Z 400m 4.5
I was being lazy and shot out of the balcony with a warm lens and I suspect massive thermal effects which resulted in a even more misty picture
Oh yes, lazy or even cold-sensitive photographers: a few weeks ago I opened the window to photograph the full moon. From the comfort of my room. None of the photos were sharp and I was already doubting the quality of the 400mm 4.5. It was only later that I realized that the living room radiator between the lens and the moon was making an unwanted contribution to the image result.
You definitely have to watch out for heat diffraction at 400mm.
Jürgen Pfeiffer
Re: March 2025
« Reply #171 on: March 17, 2025, 00:20:39 »
When you find you negative buddy, stick to it.
Re: March 2025
« Reply #172 on: March 17, 2025, 08:23:14 »
Great contrast, Paco.
Re: March 2025
« Reply #173 on: March 17, 2025, 14:33:04 »
Thank you John
Re: March 2025
« Reply #174 on: March 17, 2025, 16:00:59 »
Perspective   (Also RGB)
Z9  50/1.4G
Re: March 2025
« Reply #175 on: March 17, 2025, 17:56:43 »
These cheerful Tussilago flower heads are just what I need on a gloomy day :)
Again, the old champion Ultra-Micro-Nikkor 28mm f/1.8 on a modified Nikon 1V1.
Re: March 2025
« Reply #176 on: March 17, 2025, 20:22:34 »
Spring is been severely delayed by cold weather, but the calender says it should be spring? The little Tussilago farfara read the calender news, however, and decided to raise their little flower heads aboveground.
Ultra-Micro-Nikkor 28mm f/1.8 on one of my modified Nikon 1V1 bodies. If 1V1 is "obsolete" by today's standards., what about the UMN 28/1.8 from early '70s? Obviously merely industrial waste, to be thrown away. I'll keep that in mind.
Oh that is a very nice picture
Re: March 2025
« Reply #177 on: March 17, 2025, 20:24:05 »
I just ckecked: the Z4.5/400S is 30 Gramms heavier and 3 Centimeters shorter, so about same same
Re: March 2025
« Reply #178 on: March 18, 2025, 00:43:38 »
I know the way.
  D5, 70-200 2.8 fl
Re: March 2025
« Reply #179 on: March 18, 2025, 06:53:57 »
I know this is a cliché and hackneyed subject -- yet, when the sky at dusk explodes, it's hard not to look for the nearest camera. Which in this case was the Zf and Nikkor 400mm f/4.5Z.
The added benefit of this combination was it allowed me shooting hand-held at slow shutter speeds like 1/30-1/50 sec. After all, the sun had set long ago so darkness prevailed.
