Author Topic: November 2024  (Read 71986 times)
kasperbergholt
Re: November 2024
« Reply #15 on: November 02, 2024, 12:26:10 »
-- Kasper Bergholt
Re: November 2024
« Reply #16 on: November 02, 2024, 13:27:35 »
Nearly 50 years the Saturday market was on the Koningsplein.  Today it has been moved permantently to a different square because the Koningsplein will be a park in the future.
Z6 50/1.8S
KarlMera
Re: November 2024
« Reply #17 on: November 02, 2024, 14:02:14 »
Spectral colors
Re: November 2024
« Reply #18 on: November 02, 2024, 14:02:38 »
Many thanks Fons - did you solve the Zf AF issues?
For the greater part i have tackled the issue by locking the focus point in a central position. Over
time i noticed that it s a thing that happens more often among the mirrorless also different brands like Sony etc.
Cameras misfocus or don't focus at all, etc..
Re: November 2024
« Reply #19 on: November 02, 2024, 17:07:41 »
November 2
maintenance
Zf  -  Viltrox 16mm f/1.8
Ian Watson
Re: November 2024
« Reply #20 on: November 02, 2024, 17:11:33 »
Ian, if you chose a better angle you could use foreshortening to make your dog look a little less long.
Thanks for the suggestion, David. I had to look up foreshortening. I can see how it would work when drawing. Is the angle that you have in mind a bit higher?
Do I get extra credit for alliteration?
Yes  :D
Ian Watson
Re: November 2024
« Reply #21 on: November 02, 2024, 17:12:27 »
Amen.
Nikon Zf, 35mm f/1.8S.
Re: November 2024
« Reply #22 on: November 02, 2024, 20:00:41 »
My x-t3 also has a temperemental auto focus
Settings that work on my D800 behave differently and I rarely get the sharpness I can obtain with the D800, specially with moving subjects,  static subjects are usually not a problem
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
Re: November 2024
« Reply #23 on: November 02, 2024, 21:18:25 »
Granada in November. Murcia.
Reflex-NIKKOR 500 mm 1:8
aerobat
Re: November 2024
« Reply #24 on: November 02, 2024, 23:05:56 »
KKL Lucerne - ZF & Voigt 40mm f1.2
Daniel Diggelmann
Re: November 2024
« Reply #25 on: November 03, 2024, 01:58:54 »
Yes  :D
Any angle where the head of your dog is closer to the lens than the tail. :)
A short telephoto such as an 85mm or 105mm on 36x24mm format helps without being obvious.
Dachshunds make sweet pets but they are also fierce hunters. I miss Moxie. I miss all my dogs.
Best,
KarlMera
Re: November 2024
« Reply #26 on: November 03, 2024, 11:15:32 »
Not dark, cold and rainy
Re: November 2024
« Reply #27 on: November 03, 2024, 18:26:57 »
Very sweet and colourful meadow:)
Re: November 2024
« Reply #28 on: November 03, 2024, 18:37:45 »
November 3
A new candidate?
Zf  -  Z 85mm f/1.8S
Re: November 2024
« Reply #29 on: November 03, 2024, 19:07:06 »
  Nice colorful. I like the sensation of movement too
