Author Topic: September 2024  (Read 77594 times)
Re: September 2024
« Reply #15 on: September 02, 2024, 17:35:06 »
Great summershot, Paco!
  Thank you! It was a memorable evening!
Re: September 2024
« Reply #16 on: September 02, 2024, 17:59:21 »
Distant thunderstorm
This is superb Jürgen
Hayfield laid to dry
How the stacking has influenced the d.o.f. is a bit lost on me Birna.
But there's something about the vibrancy of the grass which feels larger than life
Re: September 2024
« Reply #17 on: September 03, 2024, 00:11:57 »
Same principle as the focus stacking approach used for macro and microscope work, but on a much bigger scale. Best done with a medium long lens to avoid scene warping away from the centre.
With the view camera one usually tilted either front or rear standards to redistribute DOF. That came at a cost for the geometry. Thus the emulation sketched here makes less geometric distortion and still has the zone of DOF as a plane normal to the optical axis, instead of the cone you got with the view camera. Either approach work well within their constraints, but the stacking is better if tall objects are encountered, and the scene is static.
Re: September 2024
« Reply #18 on: September 03, 2024, 00:13:03 »
Still water runs deep.
AFS 300 PF, Df.
Re: September 2024
« Reply #19 on: September 03, 2024, 17:15:18 »
September 3
kintsugi?
Zf  -  Z 28mm f/2.8
Re: September 2024
« Reply #20 on: September 03, 2024, 22:25:13 »
Full of healthy calories and very tasty. Breakfast of the champions.
  D2x, 58mm 1.4g
Re: September 2024
« Reply #21 on: September 04, 2024, 11:17:51 »
September 4
Had the recently acquired Z 28mm f/2.8 on the Z7_2 at neutral settings @ f/3.5, iso 64, 10 sec exposure.
Not bitingly sharp yet pleasing, sometimes referred to as micro contrast, low elements lens design.
Re: September 2024
« Reply #22 on: September 04, 2024, 14:30:00 »
September 3
kintsugi?
Zf  -  Z 28mm f/2.8
Apparently, yes.
Re: September 2024
« Reply #23 on: September 04, 2024, 14:41:31 »
Re: September 2024
« Reply #24 on: September 04, 2024, 15:06:16 »
first trial
Is it your DIY job?  Nice start.
Re: September 2024
« Reply #25 on: September 04, 2024, 15:24:15 »
Martha, my friend. Looking for some interesting china bowls to break ;)
Lars Hansen
  • Zealand, Denmark
Re: September 2024
« Reply #26 on: September 04, 2024, 16:26:54 »
Wabi-sabi philosophy?
Re: September 2024
« Reply #27 on: September 04, 2024, 16:57:34 »
Indeed no-thing is perfect, please relax!
Re: September 2024
« Reply #28 on: September 04, 2024, 17:17:32 »
AFS 300 PF, Df.
Tiefe Brunnen muß man graben
Wenn man klares Wasser will
Rosenrot, oh Rosenrot
Tiefe Wasser sind nicht still
(Rammstein)
kasperbergholt
Re: September 2024
« Reply #29 on: September 04, 2024, 17:44:06 »
Nikon Zf, Z Nikkor 28mm 1:2.8
Wauv!
-- Kasper Bergholt
