Author Topic: March 2024  (Read 75443 times)
Re: March 2024
« Reply #210 on: March 22, 2024, 18:57:07 »
The first sun light at Hallingskarvet this morning, just when I ate breakfast.
Fyrste streif av sol by Asle Feten, on Flickr
Nice view for a breakfast  :)
Ian Watson
Re: March 2024
« Reply #211 on: March 22, 2024, 21:12:40 »
A less inspiring view. The calendar insists that we are now in spring.
Nikon Zf, 24mm f/2.8 AI.
Re: March 2024
« Reply #212 on: March 22, 2024, 21:30:59 »
The calendar usually has it about right :)
Must be some serious methane production in that pond?
Re: March 2024
« Reply #213 on: March 23, 2024, 05:35:17 »
Morning of the diffused sun.
Re: March 2024
« Reply #214 on: March 23, 2024, 05:37:28 »
Nice Dalmatian ground.  :)
timh
  • uMhlanga, South Africa
Re: March 2024
« Reply #215 on: March 23, 2024, 10:38:50 »
I went for a walk in the uMhlanga village this morning, and met these two friendly guys who insisted that I take their picture.
Nikon D90 + AF Nikkor 50mm f/1.8D.
Timothy Hodgkinson
Re: March 2024
« Reply #216 on: March 23, 2024, 11:54:46 »
Cheers :)
Re: March 2024
« Reply #217 on: March 23, 2024, 12:01:12 »
One of my recurring subjects -- a badly cut silver birch on a forest clearing. Done it so many times with different results every time.
Here an IR interpretation with my newly acquired AFS Zoom-Nikkor 80-200mm f/2.8 ED D which I puchased after having used Paco's AF D on my recent Spanish meet-up with him. The later lens is very good for IR, but alas won't focus by AF on my Z5 or Z6 modified cameras. That makes using it a little awkward thus I had hoped the AFS version would keep the good IR rendition and offer decent AF. It does to a large extent, however unlike the previous 'D' version, therre is some vignetting in IR. Not that bothersome and I probably can live with this small drawback.
Re: March 2024
« Reply #218 on: March 23, 2024, 13:00:14 »
I like the bluish color and 3-D rendition perfect for this bleak winter scene.
It is surprising to know that the AF-D 80-200 f2.8 zoom for FX format vignettes such noticeably even on this frame apparently with its both sides trimmed.
Re: March 2024
« Reply #219 on: March 23, 2024, 13:23:37 »
I'm surprised as well. This was wide-open at f/2.8. The frame is trimmed on either side, as you surmised.
Do note this is the AFS, not AF D, version. Paco had the latter and it behaved differently.
Ian Watson
Re: March 2024
« Reply #220 on: March 23, 2024, 15:24:48 »
I had seen the pattern on several ponds in the area. Thanks for telling me the cause!
Ian Watson
Re: March 2024
« Reply #221 on: March 23, 2024, 15:26:55 »
A much prettier spring morning. Clear sky, fresh snow and -10°C......
Re: March 2024
« Reply #222 on: March 23, 2024, 19:55:14 »
Methane is the common end result from decomposition of organic matter in water, when oxygen levels go low in winter. Depending on the surface ice qualities and thickness, the methane is either trapped as bubble(s) in the ice, or burst through like a small explosion; in the latter case making the characteristic pattern of rays branching out from a centre. Like this example shown below.
Always walk carefully on, or better avoid, ice showing signs of methane production as the ice might break -- I can attest to this happens easily and the experience is chilling :)
Re: March 2024
« Reply #223 on: March 23, 2024, 20:03:54 »
Early sun and the morning newspaper
D1X  AF-D  50/1.4
Re: March 2024
« Reply #224 on: March 23, 2024, 20:45:53 »
March 23
dogs
Zf, Z 40mm f/2
