Author Topic: December 2023  (Read 51775 times)
aerobat
Re: December 2023
« Reply #30 on: December 06, 2023, 00:17:24 »
superbe Airy!
Daniel Diggelmann
aerobat
Re: December 2023
« Reply #31 on: December 06, 2023, 00:20:42 »
Klausjagen Küssnacht 2023 - D850 & AF-S 24mm f/1.8
Daniel Diggelmann
Re: December 2023
« Reply #32 on: December 06, 2023, 07:44:22 »
Cold. Cold. Bitterly cold.
And dark.
Z30, 50/0.75
Kim Pilegaard
  • "Nikea"
Re: December 2023
« Reply #33 on: December 06, 2023, 11:09:22 »
A photo of Forsythia buds. Leitz Focotar 50/4.5 on Novoflex bellows. Stack of 70 images. 2.1x enlargement on sensor.
Kim
Re: December 2023
« Reply #34 on: December 06, 2023, 15:26:58 »
Nice, but why use the 45MPix frame? Then you have to set jpg quality very low to keep the posted image within our file size limit ??
Much better to reduce pixel size I(say max. 2000 pix on the major axis), then use proper processing to be able to render a tack sharp image. You will then have even smaller file size, and much better results.
Re: December 2023
« Reply #35 on: December 06, 2023, 16:46:38 »
December 6
5G
Zf, 35mm f/1,4g
Re: December 2023
« Reply #36 on: December 06, 2023, 20:39:28 »
Some color on a grey day
Df 58G
Ian Watson
Re: December 2023
« Reply #37 on: December 06, 2023, 20:54:31 »
As far as I can tell, this is a Cayuga Duck.
Nikon Z6, 200-500mm f/5.6E at 400mm.
Re: December 2023
« Reply #38 on: December 06, 2023, 21:29:11 »
Re: December 2023
« Reply #39 on: December 06, 2023, 22:49:10 »
Checkmate in 2 moves. Lille, Dec. 6.
Zf, Voigt Nokton 50/1.0 at 1.4
Re: December 2023
« Reply #40 on: December 07, 2023, 00:17:03 »
overground construction
Kim Pilegaard
  • "Nikea"
Re: December 2023
« Reply #41 on: December 07, 2023, 09:40:44 »
Many thanks for the suggestion, Birna. I wasn't aware of this issue. What kind of processing do you mean - sharpening after reduction?
Kim
Re: December 2023
« Reply #42 on: December 07, 2023, 11:02:58 »
December 7
nosedive
Zf, 35mm f/1.4g
Re: December 2023
« Reply #43 on: December 07, 2023, 11:41:09 »
Urban autumn.
Re: December 2023
« Reply #44 on: December 07, 2023, 11:53:38 »
Kim: Always do a processing to maximise viewing quality. It is usually better to do sharpening at the final stage. Contrast enhancement might be done earlier.
