Author Topic: Februari 2023  (Read 36446 times)
Re: Februari 2023
« Reply #135 on: February 15, 2023, 18:13:10 »
Are we seeing a Rodenstock-inspired spring??  :)
Re: Februari 2023
« Reply #136 on: February 15, 2023, 19:29:13 »
Yes, that sounds like a great idea, Birna  ;)
Re: Februari 2023
« Reply #137 on: February 15, 2023, 19:37:24 »
Very interesting adapter! Hope to see it in detail on a new thread; What the nerds do ;)
I'm collecting the parts for #2 adapter ... will record the progress ... ridiculously simple solution will be disclosed :)
Re: Februari 2023
« Reply #138 on: February 16, 2023, 00:01:13 »
 Looking forward to it and the "Rodenstock Inspired Spring"  :)
Re: Februari 2023
« Reply #139 on: February 16, 2023, 00:09:20 »
High key hand.
  Z6, 85mm 1.8s
Re: Februari 2023
« Reply #140 on: February 16, 2023, 01:38:26 »
Before the dawn.
Re: Februari 2023
« Reply #141 on: February 16, 2023, 01:45:53 »
Marvelous how the short register distance of mirorless ILC cameras can breathe new life (such as infinity focus) into older lenses once people figure out how to mount them onto the mirrorless bodies.
The Rodenstock Heligon 100/1.6
Working on the adapter for the  new Z-mount. This is a shot with the FTZ adapter and 11mm and 18mm Meike extension rings on the Z6
Re: Februari 2023
« Reply #142 on: February 16, 2023, 08:15:57 »
The 2mm additional register distance of the Z Nikon (16mm) vs Sony (18mm)  is in fact the key factor. Properly done there is no longer an acute danger of the rear lens getting in touch with the sensor surface. In fact, even the shutter shield of the Z9, if it is activated, will clear. The gap in the latter case is small, however, so one can set the camera to not open and close the shield whilst the lens is mounted. Or, focus the lens off infinity when the camera is turned off.
As I said earlier, the Oude Delft Rayxar 50mm f/0.75 has a slightly larger imaging circle than the TV-Heligon, and the difference means one can use almost 24MPix of the 45MPix Z9 for some close-ups at least. The tulips I purchased for Valentine's Day is a fitting test subject :) The depth-of-field is vanishingly narrow.
Re: Februari 2023
« Reply #143 on: February 16, 2023, 08:35:51 »
Great result with that Oude Delft.
Re: Februari 2023
« Reply #144 on: February 16, 2023, 08:36:35 »
Feeding the birds...
Nikon D3s  AF-D 180/2.8 D
Re: Februari 2023
« Reply #145 on: February 16, 2023, 13:44:06 »
John that is so well framed and captured! Subject and separation is perfect  8)
Re: Februari 2023
« Reply #146 on: February 16, 2023, 13:45:32 »
Thank you for sharing the adapter! Here is very nice Leica Glow  ::) ;D
Re: Februari 2023
« Reply #147 on: February 16, 2023, 14:20:06 »
  Beautiful play with all the lines; add the subject and action isolation and it is a very interesting visual reading. The contrast of the youngster and the birds with the grey monolith in the back makes that presence somehow ominous. The living and the cement, the color and the grey, tho movement and the static, the living and the dead.
Re: Februari 2023
« Reply #148 on: February 16, 2023, 15:57:24 »
February 16
Setting up a partytent for this weekend's carnavalfestivities,
the yellow and blue balloons are the community colours,
not a political statement!
Z fc  16-50mm f/3.5-6.3
Re: Februari 2023
« Reply #149 on: February 16, 2023, 16:59:52 »
Thanks Erik and Paco.
Nice Fons, in Tilburg we have Green/Orange as the 'Carnaval Colours'   ;)
