Author Topic: Nikkor Z 40mm f/2  (Read 29431 times)
Re: Nikkor Z 40mm f/2
« Reply #60 on: January 06, 2025, 09:34:58 »
In fact, using a longer hood on the Z 40mm f/2 confers advantages when the lens is used in bad weather. Also for IR, the longer the shade, the better, as IR photography always is prone to flare issues.
F2F3F6
« Reply #61 on: January 15, 2025, 18:09:12 »
Hello Birna, the HN21 was the lenshood for the 3,5/75-150 series E, the 2,0/85 had the lenshood with spring called HS10.
« Reply #62 on: January 15, 2025, 21:27:23 »
I used the HN-21  on my 85/2. I positively dislike the "snap on" hoods which all tend to be rather "snap off". Udsually I glue the springs with epoxy glue.
« Reply #63 on: January 16, 2025, 03:59:29 »
I actually like this lens a lot. I don't know why many people are shitting on this lens despite knowing that it's made for economy and compactness  :o :o :o
Claus
« Reply #64 on: February 13, 2025, 23:45:16 »
I always have to smile.
You buy the Z 40mm because of its compactness and... then attach a large lens hood to it. ::)
Gil Aegerter
    • @gil.aegerter on Instagram
« Reply #65 on: February 14, 2025, 04:56:53 »
A lens like this is great for travel -- super compact to put in your bag. And if you might face conditions where a lens hood makes sense, that can go in separately. So there's really no size penalty.
Lotsa Nikon gear.
Lotsa Minolta gear.
BruceSD
  • Confirmed Bokeholic
    • The F/2 Guru
« Reply #66 on: February 14, 2025, 05:18:36 »
Two different times I went shooting with National Geographic photographers.   All three of them had the biggest lens hoods I've ever seen on lenses.   They told me when you're a pro and demand ultimate quality, you should use the largest lens hood that the lens will accommodate.
Also, if you look closely at the photo of the large hood, under it you will see an IR filter.  Large lens hoods are critical when shooting serious IR images.
I always try to wring the best quality out of my gear.  If I didn't feel that way, I guess I'd just shoot my smart phone all of the time.
Claus
« Reply #67 on: February 14, 2025, 18:08:44 »
...They told me when you're a pro and demand ultimate quality, you should use the largest lens hood that the lens will accommodate.
Ok, the best... for a pro... ultimate quality... with the Z 40mm ??? ... Interesting at least...
This is a point I understand completely
« Reply #68 on: February 14, 2025, 20:38:50 »
There is no contradiction between 'pro' and using the Nikkor 40/2. This lens is more than good enough.
Images are created by the photographer.
Gil Aegerter
« Reply #69 on: February 15, 2025, 05:02:23 »
True dat.
Lotsa Nikon gear.
Lotsa Minolta gear.
KarlMera
« Reply #70 on: February 15, 2025, 11:11:52 »
A short rectangular hood could be a solution, would be more effective than a round hood
« Reply #71 on: February 15, 2025, 11:25:39 »
That's true, but optimally would require a bayonet-type mount for the hood.
KarlMera
« Reply #72 on: February 15, 2025, 11:48:53 »
The lens has 52mm? Not optimal, but a cheap alternative?
« Reply #73 on: February 15, 2025, 20:38:20 »
The hood is square, but in my opinion way too wide/short for the 40/2.
Perhaps the small hood for the CV 90mm/3.5 might be used. I have to check
Update: it works. But the appearance is funny.
« Reply #74 on: February 16, 2025, 09:41:04 »
The Thypoch have square hoods!
https://thypoch.com/en/simera
