Author Topic: Nikkor Z 40mm f/2  (Read 30988 times)
Re: Nikkor Z 40mm f/2
« Reply #45 on: December 17, 2024, 10:42:28 »
I'm using the HN-3 hood, in fact a very old version with a lot of nicely engraved lettering on it. So far, it has  protected well  the 40/2 during the inevitable falls to the ground, but it does have acquired some dents and nicks over time. The 40 lens itself seemingly has survived some very bad impacts including being dropped on frozen ground or pavements.
Does the original HN-3 allow attachement of a 52mm filter on the front and more important to me, a 52mm lens cap?
The ebay offerings I see are pretty pricey for old scratched up original HN-3's - I found this alternative on Amazon that also is somewhat costly, but it allows a 52mm filter/lens cap to be attached on the front. It seems slightly shorter (HN-2 like?) and might not provide quite the same protection/shading. On the other hand for keeping it permanently attached the compact size would be an advantage. https://www.amazon.com/Haoge-Metal-NIKKOR-Compatible-Filters/dp/B0B88J2SGL/
I also found similar ones on ebay also allowing 52mm cap, for instance: https://www.ebay.com/itm/285423835491?
« Reply #46 on: December 17, 2024, 11:27:12 »
For the 40/2 I use a Nikon HR-4 hood which is a collapsible rubber hood. The 52mm Nikon cap fits the hood (both collapsed and not collapsed).
The rubber is quite thick good quality so will protect a bit if lens is dropped.
Jürgen Pfeiffer
  • You ARE NikonGear'23
« Reply #47 on: December 17, 2024, 14:17:20 »
Here you go...
Jürgen Pfeiffer
Jürgen Pfeiffer
« Reply #48 on: December 17, 2024, 14:18:35 »
and HS-12 fits also very well
Jürgen Pfeiffer
« Reply #49 on: December 18, 2024, 05:56:46 »
Here you go...
Thanks, Jürgen (and MEPER). Does the HN-3 also accommodate a filter on the front? (A filter is likely best mounted between the hood and the lens, but the threads may help to keep the lens cap secure.)
Jürgen Pfeiffer
« Reply #50 on: December 18, 2024, 09:33:38 »
Helio Øivind,
if you want to mount the filter "inside" the HN-3 hood – no, this does not work, there is no dedicated 52mm thread as in the hood shown at amazon.
Jürgen Pfeiffer
« Reply #51 on: December 18, 2024, 11:30:24 »
Thanks, anything else (rilles etc.) that might help keep the lens cap secure?
« Reply #52 on: December 18, 2024, 12:13:45 »
The HR-4 has filter thread. The HR-4 was meant for a 35mm or 50mm lens. It is quite compact.
The first image shows the 40mm with HR-4 + a 52mm filter attached in the HR-4 thread.
Jürgen Pfeiffer
« Reply #53 on: December 18, 2024, 14:21:10 »
Helio Øivind,
As shown in my photo, the lens cap snaps securely into the HN-3
Jürgen Pfeiffer
« Reply #54 on: December 18, 2024, 18:53:02 »
Thanks Jürgen and MEPER.
BruceSD
  • Confirmed Bokeholic
    • The F/2 Guru
« Reply #55 on: December 24, 2024, 05:38:00 »
I'm very pleased with the 40/2 for IR, so am  about to buy a second copy to allow other camera to share the pleasant qualities of the 40.
I tried my 40/2 lens on my Z6 with a Hoya 58mm R72 IR filter.  Set ISO to auto with a maximum of 6400, and shot the lens wide open.  The lens autofocused beautifully, with no need to do the "red IR dot" adjustment that's required with manual focus lenses.
I believe that this with be my IR rig from now on.   Thanks so much Birna for the terrific suggestion!
« Reply #56 on: December 24, 2024, 08:30:17 »
Glad you found out :)
By the way, the unevenness of light seen in that photo is a sign of vignetting with the 40mm at f/2. Not too problematic as it can quite easily be cured in the processing steps. Set a little further down the aperture range, the Nikkor Z 40 has no evident vignetting and definitively shows no hot spots.
I initially got the 28/2.8 SE Z Nikkor for IR, but while it is good that purpose, the 40/2 Z beats it hands down.
As you already commented, AF works perfectly with the 40 on the Z cameras for IR shooting. Only problem area is indoor scenes, however that results from lack of available IR light so common these days as old tungsten-based incandescent lights are being replaced by modern technology.
« Reply #57 on: January 05, 2025, 09:01:36 »
Helio Øivind,
The Nikon original HN-3 arrived, a pretty perfect match for the 40mm and that can be permanently kept on the lens. And thanks, the lens cap sure fits securely.
« Reply #58 on: January 05, 2025, 23:52:19 »
The HN-3 is for F-mount lenses with 35mm focal length and was designed to fit even if a filter was attached to the lens (you can't attach a filter in front/inside the hood). Since the Nikkor Z 40mm lens has a longer focal length and has a very small front element, the HN-3 will work without causing any vignetting even if fitted over a filter. I expect most hoods for 50mm lenses will work well for this lens.
« Reply #59 on: January 06, 2025, 08:30:02 »
You are absolutely correct, Roland. Even a hood for the 85mm f/2 (HN-21)   will not vignette at all.
