I won't disasemble my 85/.4 AIS now .... however, from what I can recall, you need to remove significant chunk of metal inside, from the wall of the rear focusing cell. The fact that this lens has CRC implemented by rear focusing complicates the chipping so call on the Dremel
The 85/1.4 in this regard is quite similar to the 16/3.5 Fisheye, both need a lot of Dremel action.
Just had a quick peek at my 85/1.4 and from what i can observe, material has been removed along an arc of about 150 degrees, starting at the midde position between the top bayonet screws, and ending beyond the mounting slit. The chipping likely was conducted by yours truly as it lacks the flawless nature of Erik's doings.
