Author Topic: April 2018  (Read 102066 times)
Re: April 2018
« Reply #30 on: April 04, 2018, 20:22:15 »
great tit shot, Bent!
great spring composition, John!
Re: April 2018
« Reply #31 on: April 04, 2018, 20:28:08 »
Thanks Frank !
Re: April 2018
« Reply #32 on: April 05, 2018, 07:33:39 »
After three months in the waitingroom---   The White Magnolia
I like the way you treat the background as the photographic main subject by using the magnolia tree as a frame.  The white magnolia flowers look quite different from either the ones commonly seen in Japan or those I saw in New Orleans.
Bent, you capture the tense between the tit and yourself, which I like.
Re: April 2018
« Reply #33 on: April 05, 2018, 07:53:19 »
Thanks Akira.
It think it is the  Star Magnolia (Magnolia stellata) https://en.wikipedia.org/wiki/Magnolia_stellata which should be native to Japan, according to Wikipedia.  Or is it rare?
Re: April 2018
« Reply #34 on: April 05, 2018, 08:07:18 »
Thank you Frank
Re: April 2018
« Reply #35 on: April 05, 2018, 09:47:03 »
Perhaps there is an upcoming spring in the future? Ice has started to break on the river nearby.
Df, 300 PF.
Re: April 2018
« Reply #36 on: April 05, 2018, 10:42:31 »
Thanks Akira.
John, interestingly, I haven't seen the star magnolia in Japan.  The magnolia commonly seen around here is Magnolia liliiflora whose color is white or purple:
https://en.wikipedia.org/wiki/Magnolia_liliiflora
Re: April 2018
« Reply #37 on: April 05, 2018, 10:58:17 »
April 5
Df - 35-200mm f/3,5~4,5 without hk-15, hn-23 is no option causing significant vignetting on the wide end,
developed in photoninja converted in photoshop :)
Re: April 2018
« Reply #38 on: April 05, 2018, 11:55:04 »
April 5
The modern vehicle of the flying Dutchman?
Re: April 2018
« Reply #39 on: April 05, 2018, 12:16:59 »
April 5
I checked the HN-23 as well, but indeed too much vignetting even affecting 50mm, which is not strange as this hood is at home with the 80-200mm zoom. HN-22 is mentioned as alternative to the hk-15.  A UV filter might help a bit as well. At least it works with my 35-70/3.5 Ai-S.
Re: April 2018
« Reply #40 on: April 05, 2018, 13:09:28 »
April 5.
How could I just pass by, when I carried a camera and found such a photogenic camellia on the way?
Re: April 2018
« Reply #41 on: April 05, 2018, 16:45:03 »
'The district Brabant will transport us'
Bus
D800E  300/4.5 ED Ai
Re: April 2018
« Reply #42 on: April 05, 2018, 18:58:34 »
in stark spring light
D500 & 1.8/20G
Re: April 2018
« Reply #43 on: April 05, 2018, 18:59:20 »
April 5
fun shot!
Re: April 2018
« Reply #44 on: April 06, 2018, 16:54:32 »
I realized i made a typo i meant the HN-24 i think the hk-10 works fine too a bit shallow maybe.
