Author Topic: I've fallen for manual focus lenses and I blame all of you!  (Read 43114 times)
gryphon1911
  • Looking For The Best Light
Re: I've fallen for manual focus lenses and I blame all of you!
« Reply #135 on: October 04, 2017, 03:31:53 »
Got out at lunch today and was able to run the Nikon 180mm f/2.8 ED AIS...FINALLY!!  Such a pleasure of a lens to use.  I had the Olympus PEN-F with me today, so the Nikon with a Fotodiox Nikon to m43 adapter.  Shot between f/2.8 and f/8.    Mostly with f/4 because of the bright sun today.
Andrew
Matthew Currie
« Reply #136 on: October 08, 2017, 18:18:24 »
The ancient 200/F4 Q remains an ongoing mystery to me.  I have this clunker of a lens, stiff focus, banged up, clumsily AI-ed with what looks like a hammer and chisel.  Even with ridiculously long extensions, it remains one of the easiest lenses I've ever had to focus manually, easy to hand hold.  It may not be state of the art sharp, but I think they coated the glass with some secret sauce.  Here's a shot straight out of the camera,  68 mm. extension tubes, D7100, hand held at ISO 400 (EXIF says it's a 55/3.5 because I forgot to change) - no sharpening, no nothing, just downsized to JPG.
« Reply #137 on: October 08, 2017, 18:48:14 »
Amassing what those old designs do even today  ;)
« Reply #138 on: October 08, 2017, 21:30:06 »
The 200/4 Q.C has almost identical optics as the original Nikkor-Q 20cm/4 from 1961. The optics were tweaked in 1967 for improved performance but the design is still essentially the same, the barrel was revised in 1969 (with possibly another minor revision of the optics) and multicoating was added in 1973. The original lens has a rather long focus limit of 3m, maybe because the designers felt it wasn't well optimised for close range, although the limit was reduced to a more useful 2m when the barrel barrel was updated. For a lens which originally only got to 3m, it is amazing how well it does at much closer distances.
the solitaire
« Reply #139 on: October 08, 2017, 22:49:18 »
The 200mm f4 Nikkor-Q and Q.C are indeed among the gems of the MF Nikkors.
Other gems, from short to long, and all just based on my personal experience with MF Nikkors:
16mm f3,5. Mine is a pre-Ai version. The Ai seems to be marginally better
20170903-DSC_7248 by b j, on Flickr
20mm f3,5 Nikkor-UD. I prefer this one over the later Ai and Ai-S versions, and over the f4 and f2,8 lenses Nikon made in this range
20170917-DSC_8172 by b j, on Flickr
35mm f2 Nikkor-O. I wasn't ever pulled towards the 35mm range, until I found this little gem.
20170910-DSC_7674 by b j, on Flickr
55mm f1,2 Nikkor-S.C. Who cares about perfect, measurable sharpness if there is so much to discover in the areas of an image that are not in focus?
DSC_0132-Edit by b j, on Flickr
200mm f4 Nikkor-Q.C. Very usable wide open. So much so, that I hardly ever see the need to stop this baby down
DSC_8207 by b j, on Flickr
The only thing that made me use the above 200mm lens less then I did before is buying another copy of a lens I sold. The 80-200 f4 Ai-S zoom Nikkor. I owned one for 20+ years, and selling it was a big mistake. When I got another copy, I immediately knew why I had missed this lens more then any other lens I ever sold. Ease of use AND excellent results. And as a cherry on the cake, it focuses all the way down to 1,2 meters.
DSC_9571 by b j, on Flickr
With the above kit in my bag, what does that leave to be desired? The 300mm f2,8*ED Ai-S of course!
20170912-DSC_7912 by b j, on Flickr
I do own a few other manual Nikkor lenses, but these are the ones that come along when I go outdoors. Not all of them, but at least 2 or 3
Buddy
« Reply #140 on: October 08, 2017, 23:04:13 »
Your photograph could have been greatly strengthened by stepping forward about 3 meters to the Buick Special or backward about 3 meters to the Chrysler 300.  Sometimes life is unkind.
I remember the 20/3.5 UD Nikkor fondly.
the solitaire
« Reply #141 on: October 08, 2017, 23:10:30 »
David, you might have been right there, but I used different lenses to portrait the Buick and Chrysler because I thought the strengths in their designs were not made for the fish eye effect ;)
Buddy
« Reply #142 on: October 08, 2017, 23:13:42 »
 :)  :D  ;)
Per Inge Oestmoen
  • Long Live NikonGear
« Reply #143 on: October 15, 2017, 15:08:03 »
I gave up on the 20/2.8 AFD (ugly plastic fantastic, poor handling) and took the alternative route with the 20/2.8 AIS instead. The new 20/1.8 AFS is very sharp, but like many of its contemporary siblings, in dire lack of charm and smooth handling.
The small 20/3.5 AI/AIS is excellent for close-ups but not my first choice for more distant subjects as the corners aren't very convincing before f/11 or so, at which point the entire image starts to fall apart. The 20/2.8 output has a nice overall feel to it, but once again, maybe not the candidate for distant landscapes.
I have not tried the Nikkor 20mm 3.5 AI/AIS.
However, I have the Nikkor 20mm 2.8 AIS and the Nikkor 20mm 1.8G ED AF-S. The AF-S version is better in the periphery, otherwise these two are largely equal. The superiority of the AF-S version is visible but not dramatic, so on the whole I have found that the AIS version holds up very well.
If used on a digital body, I will recommend the 20mm 1.8 AF-S since it is optically better and has AF.
"Noise reduction is just another word for image destruction"
Per Inge Oestmoen
Per Inge Oestmoen
« Reply #144 on: October 15, 2017, 16:33:47 »
Coatings/reflections are always nice to look at,,, shot by JA! Thanks  ;D
26822992335_c22743d8db_o by Erik Gunst Lund, on Flickr
I would be very careful not to drop that one onto the gravel.
Per Inge Oestmoen
« Reply #145 on: October 19, 2017, 12:37:28 »
Believe me - we where very careful,,,  ;D Photo by Jan Anne  8)
Erik02 by Erik Gunst Lund, on Flickr
« Reply #146 on: October 19, 2017, 14:51:56 »
Yes, we can see that :D
gryphon1911
« Reply #147 on: November 25, 2017, 23:30:43 »
Was able to get out and use the Nikkor 135mm f/3.5 Q today.   Wanted to get some test shots for a review I am working on:
Various apertures from f/3.5 - f/8.   Performed well on the Df, but that will not be a surprise to most.
Andrew
« Reply #148 on: November 26, 2017, 00:51:55 »
Performance looks decent as I interpret these results.  Similar to other Nikon 135's, like my 135/3.5 Ai, 135/2.8 Ais, and 135/2 Ais.  Don't ask why I have all of these!  I still want the older 135/2.8 K/Ai, just because it looks so cool.
« Reply #149 on: November 26, 2017, 02:01:39 »
I own a 135/2.8 AIS NIKKOR with the latest Super IC coatings and consider it an exelent lens. I also own a 135/3.5 AI and it turns in a fine performance at f/5.6. I also own a 135/3.5 Nikkor-Q with single coating primarily for nostalgic reasons. I can recommend all of these, the Nikkor-Q would be for a vintage look.
Dave who is being paged by a cockatoo.
