Author Topic: I've fallen for manual focus lenses and I blame all of you!  (Read 64652 times)
Re: I've fallen for manual focus lenses and I blame all of you!
« Reply #150 on: November 26, 2017, 03:17:37 »
Performance looks decent as I interpret these results.  Similar to other Nikon 135's, like my 135/3.5 Ai, 135/2.8 Ais, and 135/2 Ais.  Don't ask why I have all of these!  I still want the older 135/2.8 K/Ai, just because it looks so cool.
I own a 135/2.8 AIS NIKKOR- with the latest Super IC coatings and consider it an exelent lens. I also own a 135/3.5 AI and it turns in a fine performance at f/5.6. I also own a 135/3.5 Nikkor-Q with single coating primarily for nostalgic reasons. I can recommend all if these, the Nikkor-Q would be for a vintage performance.
Dave who is being paged by a cockatoo
« Reply #151 on: November 26, 2017, 10:27:54 »
135mm /2.8 very nice lens for some inexplicable reason i have not mounted it for some time now, the images are encouraging to pick it up once again
« Reply #152 on: November 26, 2017, 20:52:59 »
Was able to get out and use the Nikkor 135mm f/3.5 Q today.
Be aware there are two optical versions of this lens. The original began life as the rangefinder version, the same optics were ported over to the F-mount lens. Early samples have 9 aperture blades, later reducing to 6 blades. Serial nos from 720101 to at least 847365.
In 1969 the optics were updated, although it remains a 4 element sonnar design. This one has a scalloped aperture ring and 7 aperture blades which are curved (not fully rounded though), so background highlights have a pleasant organic shape. Serial nos from 865101 to 981870. Multicoated version from no 111111 and late pre-AI version with modern barrely style from 158101. I've used this version a little, rendition is similar to the 105/2.5, with good sharpness and nicely rounded bokeh.
rolubich
« Reply #153 on: November 27, 2017, 01:14:40 »
I have both (13.5cm f/3.5 Q 9 blades and 135mm f/3.5 QC) and unless there aren't bright areas in the frame they behave about the same (in a very good way) in my opinion.
Here
https://www.nikonclub.it/forum/uploads/ori/201612/8b3cd2eeca561c6d4b0c20ae39c759d7.jpg
the 13.5cm on Sony A7RII @ f/5.6 or f/8, full resolution (just cropped a little), sharpness is up to 42MP.
gryphon1911
  • Looking For The Best Light
« Reply #154 on: November 27, 2017, 01:50:56 »
Here
Cute pup!  :D
Andrew
gryphon1911
« Reply #155 on: November 27, 2017, 01:52:32 »
Got the 200mm f/4 QC out today on the Df:
Andrew
gryphon1911
« Reply #156 on: November 27, 2017, 01:53:46 »
Then I swapped it out for the 300mm f/4.5 AI:
Andrew
« Reply #157 on: November 27, 2017, 18:13:56 »
wow, the look you got from the woman carrying the mac
gryphon1911
« Reply #158 on: November 27, 2017, 21:27:06 »
I know...lol
Andrew
« Reply #159 on: November 27, 2017, 22:25:46 »
Yes, great !!
That 200 Q C is a real gem.
CS
« Reply #160 on: November 27, 2017, 22:48:22 »
Yes, and a striking resemblance to the character in the last image!
Carl
« Reply #161 on: November 28, 2017, 00:48:28 »
A few thoughts on the 135/2.8 AI & AIS. They are opticaly the same. They're not frozen smoke like some modern AF lenses but they aren't too heavy. The f/2.8 aperture extends their usefulness a little earlier and later in the day. Bokeh is nice and smooth at large aperture. They make a great tight head shoot portrait lens. The focus throw on the AIS is a reasonable 180* while the AI is quite long at 270* which makes the lens more difficult to focus on a fast moving subject but more precise for other subjects. They both have a built-in hood. If the one on the AI is as bad as the AIS I'd consider it useless and use a Nikon HS-14 hood instead. The built-ins are very wobbly.
All in all my picks for AI & AIS short to medium telephotos are 105/2.5, 180/2.8 ED and 135/2.8. I have a lube contaminated 85/1.4 AIS and don't know where to place it. It was to me a fabulous lens but I prefer the 105mm and 180mm focal lengths.
Given the performance and price of the 135/2.8 AI & AIS I can't think of a reason not to own one.
« Reply #162 on: November 28, 2017, 01:03:15 »
I had to look again: it's true!
« Reply #163 on: November 28, 2017, 02:51:48 »
The AIS 135/2.8 was one of the first lenses I bought. At the time I figured it offered a bit more bang for buck than the 105/2.5, being the same price, with more reach and only marginally bigger. It was my "poor mans 80-200/2.8", with a focal length mid-way of the zoom I could cover pretty much the same as the zoom with a bit of foot work, it has the same aperture, focuses closer, much smaller and much cheaper, and probably sharper too.
A modern version with better correction of colours for digital imaging would be welcome ...
gryphon1911
« Reply #164 on: November 28, 2017, 03:03:56 »
Good info, thanks for that.
Andrew
