Author Topic: What is the Most Narrow Extension Tube for the Nikon Z Lenses  (Read 2938 times)
I am just wondering if there are any very narrow (thin) extension tubes for the Nikon Z camera?
Since there are no good macro lenses I know of for the Z7 II Nikon, I am trying to cobble together an autofocus Z lens with a very narrow extension. The best I have so far is the 85mm Z f/1.8 and an 11mm extension. Any ideas?
Re: What is the Most Narrow Extension Tube for the Nikon Z Lenses
« Reply #1 on: May 02, 2021, 14:21:00 »
BORG makes a thin Z to M48.9 P0.75 adapter whose part number is 5032:
https://www.tomytec.co.jp/borg/products/partsDetail/summary/756
Borg also makes an M49.8 to M42 adapter ring to make the Z-mount compatible with the more common M42 P1.0 thread.
In the second image, the two rings on the bottom right which are BORG Sony E and m4/3 mounts which look similar to the Z-mount mentioned above.
The ring on the top right is the M49.8 to M42 adapter.
« Reply #2 on: May 02, 2021, 14:25:10 »
How thin are these rings, please?
« Reply #3 on: May 02, 2021, 14:26:10 »
I understood Michael to enquire about extension with pass-through contacts. Otherwise there will  be no AF :(
I think 11mm is about the narrowest you can get these days.
« Reply #4 on: May 02, 2021, 14:29:12 »
Oops...I failed to read the second paragraph.   :-[   I'm afraid its thickness is not indicated in their website.
« Reply #5 on: May 02, 2021, 14:29:32 »
There is a 10mm one I believe from Fotodiox that is part of a 2-adapter set, but the set goes for over $200....
« Reply #6 on: May 02, 2021, 14:32:24 »
Kenko/Tokina makes a set of Z-mount 10mm and 16mm extension rings with contacts.  But the set also costs around 200 USD:
https://www.kenko-tokina.co.jp/imaging/eq/eq-digital/close/tube/4961607515501.html
« Reply #7 on: May 02, 2021, 14:35:47 »
I would like to, of course, see one about 8mm which would preserve the quality of the lenses used with it a bit more.
Snoogly
  • Flipping the bird
« Reply #8 on: January 05, 2026, 21:17:00 »
This is an older post - but has anyone been able to find a thinner Z extension tube, with electrical contacts?
« Reply #9 on: January 06, 2026, 05:52:54 »
I'd like an 8mm, but 6mm (like the old f-mount K1 tube) would be even better for me.
