I'm familiar with the strong warnings of Birna, the lens is not ment for a DSLR.
The lens is not too long for the FTZ (only 1-2 mm) and will not touch the sensor.
Could a K1-ring help?
The K-1 would throw focus way off. No hope of seeing infinity.
It *is* possible to use the 2.1cm lens on a Z camera if you juggle around with adapters. However it is hardly worth the bother except for satisfying the urge to use an ancient lens on a modern camera
Focusing is very awkward and near limit is around 0.9m, which makes the lens almost useless in practice. Image quality is so-so, nothing to write home about. The Voigtländer 21mm f/4 lens is more compact, much easier to focus, and can be had for a lesser price as well. I mount it via my Nikon(RF)-Z adapter. While the Voigtländer also stops at 0.9m, it has a better image quality.
Best of these wide and still quite easily available RF lenses is the Voigtländer 25mm f/4. My definitive favourite. It is downright cute on any Z camera and delivers very good image quality, a quality which also extends into the IR range.
Nikon modified the 2.1cm to make it possible to use on the early Nikkormats. The first version of the 2.1cm had too massive rear flange.
Never ever use the 2.1cm on other than Nikon F, F2, and the early Nikkormat. You
will destroy the mirror of your SLR/DSLR.
Chris, the serial no. of my 2.1cm Nikkor is less than 100 units away from your lens
