Author Topic: SB-21 Adapter rings question? necessary?  (Read 2186 times)
jamesmustain
« on: February 19, 2021, 05:52:36 »
Empty post
Re: SB-21 Adapter rings question? necessary?
« Reply #1 on: February 19, 2021, 09:07:23 »
No, not mandatory, but the correct rings ensure the SB-21 flash head is seated securely and firmly to the lens.
Step rings have a less efficient form factor to hold the SB-21. But using them is doable, with some precautions.
« Reply #2 on: February 21, 2021, 01:12:52 »
These Nikon Speedlight manuals downloadable from Nikon Canada might be helpful...
https://cdn-10.nikon-cdn.com/pdf/manuals/archive/SB-21.pdf
Scroll down half way for the beginning of the English section of the SB-21 Manual.
https://cdn-10.nikon-cdn.com/pdf/manuals/Speedlights/SB-29.pdf
Also if the lens you wish to use the SB-21 with is an AF or AF-D 60/2.8 Micro-Nikkor a Nikon Adapter UR-3 is available new from B&H Photo USA on special order for $30.00 (USD). The Nikon UR-3 should be available from other suppliers and in various countries.
Perhaps something here will help,
