Author Topic: Petzval ... ????  (Read 20012 times)
Re: Petzval ... ????
« Reply #30 on: August 20, 2015, 10:56:32 »
Now I got interested, too :)
I love blurry and bokeh capable lenses.
A quick search on eBay resulted in:
http://www.ebay.de/itm/Cyclop-1-5-85-Helios-40-2-M42-Portrait-Objektiv-bokeh-monster-Petzval-swirl-/261997564089?hash=item3d004590b9
It's not expensive but it's an M42 mount lens.
Wouldn't know how difficult it would be to modify for Nikon f-mount?
Buy it'! Even if it's just for the super cool name :*
I'll put a F-mount on it no problem, I'm sure Bjørn will sell you a custom CPU to go
Should be possible to get infinity but yes who cares...
« Reply #31 on: August 20, 2015, 10:58:04 »
Or we add a Nikon 1 mount as well, do this all the time with Bjørns lenses - Go for it!
« Reply #32 on: August 20, 2015, 11:11:19 »
You buy it then!  8)
« Reply #33 on: August 20, 2015, 11:13:33 »
He he  ;D
« Reply #34 on: August 20, 2015, 11:21:11 »
I ended up with your Heligon, and I see I'll end up with your Cyclop too ;P
You wanna share?
Björn Carlén
  • Errare humanum est
    • flickr
« Reply #36 on: August 20, 2015, 11:44:42 »
Here is an other New Petzval 85 shot. This time without any specular highlights. And this is about as close as it can focus, without any help.
Wealth.
Björn Carlén
Huddinge, Sweden
« Reply #38 on: August 20, 2015, 11:51:55 »
Remove all aperture blades from the Helios, or epoxy the aperture at f/1.5 setting. Now you can have a Cyclop as well .....
Björn Carlén
    • flickr
« Reply #39 on: August 20, 2015, 12:11:53 »
The above image was shot totally open. I had left my aperture plates at home, so I put some black tape on the waterhouse slot, to avoid stray light, and used it like that. The biggest aperture plate is f/2,2 so presumingly this is the same. What do you say – could there be any downsides of shooting it in this manner?
Björn Carlén
Huddinge, Sweden
« Reply #40 on: August 20, 2015, 12:16:49 »
Yes , there can/will be a slight difference in rendering depending on where the light rays gets cut in the optical assembly.
A quick test to see this is to make a small square opening cut in a pice of cardboard and place it in front of the lens and the behind the lens.
Then look at the OOF rendering
« Reply #42 on: August 20, 2015, 12:20:11 »
Apart from getting very short exposures, and short depth of field, I see no harm in using any lens at its widest aperture setting.
Mechanical vignetting can occur, though.
« Reply #43 on: August 20, 2015, 12:35:26 »
yes and no.
The lens is f/2.2 and the largest aperture insert is f/2.2 this could indicate that it is needed to cut the light rays at the 'correct' intended position.
It could also indicate that they would not design a 'door' without the waterhouse 'blade'....
Björn Carlén
    • flickr
« Reply #44 on: August 20, 2015, 12:53:11 »
Another simle test would of course be shooting the same object once with the 2,2 blade, and once with just an empty waterhouse. I've just been too lazy for that up until now.
Björn Carlén
Huddinge, Sweden
