Author Topic: Nikkor-S 35mm f/2.8 Auto! (the better version)  (Read 4493 times)
« on: December 06, 2020, 14:11:10 »
https://richardhaw.com/2020/12/06/repair-nikkor-s-35mm-f-2-8-auto-late-version/
wasnt expecting this to be a lot better than the older one :o :o :o
the older one retained some traits of the tessar where it was based
Re: Nikkor-S 35mm f/2.8 Auto! (the better version)
« Reply #1 on: December 06, 2020, 22:21:43 »
"Here it is beside the earlier version. Can you identify which lens is the later one?"
If you are trying to identify the Nikkor-S with the early and late optical designs, you won't have much luck because both the lenses shown here have the same optics. These are the later type with the modified gauss design :o :o :)
The older Nikkor-S uses a modified Tessar design, the best way to distinguish them are:
1. the older Nikkor-S is always marked 3.5cm, the newer optical design is always marked 35mm
2. The older lens has a longer barrel - 58mm from the mount, the newer one is more compact at 45.5mm :)
« Reply #2 on: December 07, 2020, 01:18:44 »
Yikes! Is it!? So it terminated in cm? :o :o :o
« Reply #3 on: December 07, 2020, 02:58:57 »
Yes. Put your tick-mark 3.5cm next to the two above, you'll quickly see the differences.
« Reply #4 on: December 07, 2020, 03:30:06 »
i checked my notes and you're right! now im on the look out for a 3.5cm version :o :o :o
it's kind of rare these days...
how much do they go for?
« Reply #5 on: December 07, 2020, 04:03:49 »
Total production of the Nikkor-S 3.5cm would appear to be less than 7500 units, so pretty uncommon.
Tick-mark lenses are usually regarded as common, yet the total run of tick-mark Nikkor-S 5cm 1:2 lenses is not that much less than the number of 3.5cm lenses of any sort. I haven't checked prices recently but most people don't know the difference between the Nikkor-S 3.5cm and 35mm versions, so if you are lucky you can pick them up cheap :)
« Reply #6 on: December 07, 2020, 06:01:20 »
I will message you, I will show you something :o :o :o
