Author Topic: 35-70 f/2.8D!!!  (Read 2840 times)
35-70 f/2.8D!!!
« on: November 26, 2020, 14:05:09 »
https://richardhaw.com/2020/11/26/repair-af-zoom-nikkor-35-70mm-f-2-8d/
always hazy :o :o :o
but it earned me some money back then ::)
Re: 35-70 f/2.8D!!!
« Reply #1 on: November 26, 2020, 14:17:32 »
Thank you!
My first PRO zoom, together with the AF-D 20-35mm and AF 80-200 MM f/2.8
Loved it although it on F4 and F5 but it was kind of longish focal length on D1 and D2Xs was replace by workhorse 28-70mm AF-S f/2.8 come D3 and it was replaced by 24-70mm AF-S f/2.8 then the E - OMG so many lenses  :o
Re: 35-70 f/2.8D!!!
« Reply #2 on: November 26, 2020, 19:49:25 »
Good review Richard!  Thanks for the write-up.  I still like the lens on the 'modern'  Nikons :)
Re: 35-70 f/2.8D!!!
« Reply #3 on: November 26, 2020, 23:43:35 »
do your samples flare terribly? all of the ones that i used throughout the years flared  :o :o :o
Re: 35-70 f/2.8D!!!
« Reply #4 on: November 27, 2020, 09:04:14 »
My earlier samples did.  I have now a very late sample, and the flare is acceptable and useful.
Probably Nikon changed something to the drawbacks over the years.
Re: 35-70 f/2.8D!!!
« Reply #5 on: November 29, 2020, 05:18:14 »
Think of the flare as a "feature" of the AF-D 35-70/2.8 and you'll enjoy the lens more.  :D
After buying an AF-D 28-70/35-4.5 Nikkor I found I could tell all too frequently which lens, the AF-D 28-70/3.5-4.5 or AF-D 35-70/2.8 I'd used by the flare. This didn't require having the sun in or near the frame for the AF-D 35-70/2.8. A large bright area in front of the 35-70/2.8 was enough to cause problems. The AF-D 28-70/3.5-4.5 has 8 elements in 7 groups with one aspherical element and is pleasingly sharp with low flare and ghost. I get excellent images at f/5.6 to f/8.0 with the 28-70/3.5-4.5. f/8.0 probably tightens up the edges of the image. I haven't been using it much as my D800 performs AF better with AF-S, G lenses.
My AF-D 35-70/2.8 has an alignment problem and as I recall the upper left quadrant exhibits image smearing until about f/5.6~f/6.3. It now serves as a paper weight. I probably bought the AF-D 28-70/3.5-4.5 to fill the gap. The review at http://www.naturfotograf.com/lens_zoom_02.html#AF28-70 gave me the confidence to buy the 28-70/3.5-4.5.
