Author Topic: October 2020  (Read 58610 times)
Re: October 2020
« Reply #45 on: October 05, 2020, 09:49:04 »
Three amigos.
  D5300 ir, 80-200mm 2.8 ed. That lens does very well in infrared.
  Question, does depth of field work different in infrared?
Great catch ;)
In UV the wavelength is shorter so a more defined image is possible given the lens permits, for IR I would guess dof is alittle less since it's only IR light waves that are rendered, but most likely it's very little difference,,,
Re: October 2020
« Reply #46 on: October 05, 2020, 09:50:59 »
Oktober 4
Cacaofabriek, Helmond
Z6  28/1.4
So good! A really superb framing and subject placement, as well as post processing Fons!You must print this large and frame it!
Re: October 2020
« Reply #47 on: October 05, 2020, 11:58:40 »
I veered off tangentially from the ever-present chores to do a quick UVIVF (ultraviolet induced visible-light fluorescence) photomacropgraph of the pollen of a Malva moschata. Turned out the stamens and anthers withered so quickly that my attempt of doing a focus stacking at 5X was thwarted. I could only use a narrow sliver of the intended stack leading to an image with a cacophony of chaotic colours and partly sharp detail. I submit it respectfully, nonetheless.
Z7, Laowa 25mm f/2.8 at f/2.8, 5X, UV 365nm LED light ('NEMO'). The resemblance of the pollen  grains to particles of Covid-19 virus is fortuitous.
Re: October 2020
« Reply #48 on: October 05, 2020, 12:12:16 »
What a special and unique view. Lovely.
Re: October 2020
« Reply #49 on: October 05, 2020, 12:23:45 »
Birna, that is amazing!  Rather than the speed of withering, I would wonder how the aquatic plants could stand still in the water during the stacking.
Re: October 2020
« Reply #50 on: October 05, 2020, 12:37:27 »
They usually are suspended in water. However, shooting through an air-water interface makes UVIVF well-nigh impossible. Frankly, I hadn't expected the Malva flower to wither this quickly as the entire stack was shot in a 5 minutes interval. But it certainly did and made hopeless for Zerene Stacker to track and correct the changes.
Re: October 2020
« Reply #51 on: October 05, 2020, 12:49:54 »
Surreal and Apocalyptic at the same time - Marvelous!
Re: October 2020
« Reply #52 on: October 05, 2020, 12:58:10 »
Thanks Erik
Re: October 2020
« Reply #53 on: October 05, 2020, 12:58:45 »
Special!
Re: October 2020
« Reply #54 on: October 05, 2020, 13:19:35 »
Oh, sorry, I took it granted that you were shooting an aquatic plant.  That said, it is indeed surprising that even the terrestrial flower withers so quickly that it couldn't stand for the duration of stacking.
Re: October 2020
« Reply #55 on: October 05, 2020, 13:37:35 »
Oktober 5
Classic car
D3s  24-70mm f/2.8
Re: October 2020
« Reply #56 on: October 05, 2020, 14:48:31 »
My new desert island camera and tiny carbon tripod quickly become my everyday camera:
Interesting.
I've been out walking more and more this year and often only have my phone with me.
I like the combo you're using Aerobat
Re: October 2020
« Reply #57 on: October 05, 2020, 14:49:24 »
too bad, that empty sky... but the variety of tree colours was attractive. Df, Noct Nikkor @f/8
It's lovely Airy.
Plus even the curves of the building have some grace about them
Re: October 2020
« Reply #58 on: October 05, 2020, 14:54:11 »
a quick UVIVF photomacropgraph of the pollen of a Malva moschata.
Beautiful & mind boggling
The mix of colours plus the shapes and luminescence of the pollen grains are indeed other worldly.
Re: October 2020
« Reply #59 on: October 06, 2020, 00:22:26 »
Great catch ;)
Thank you Erik
   Birna, your magic is very strong.
   Buses in Seville are colorful.
   Z6, 85mm 1.8S
