Author Topic: Carl Zeiss Jena Apo-Germinar W 8/150  (Read 6918 times)
Re: Carl Zeiss Jena Apo-Germinar W 8/150
« Reply #15 on: September 24, 2020, 19:32:51 »
yep... you can do that. but I always felt that the lens was too heavy for reversing in that way.  I was worried about bending the front threads.
It is built like a tank. It sits on my Actus solid.
« Reply #16 on: September 25, 2020, 08:13:54 »
Raeson I did not use mine and sold the 210mm + 240mm, just kept the 150mm
« Reply #17 on: September 25, 2020, 13:23:13 »
I do have a Nikon-F mount lens plate for my XL35; and I may (??) attempt to try this since the lens has just been sitting there, but it is very heavy = 1Kg. I would use a single step down ring for stability though.
Also I originally said the lens was sitting for like 8 years... it is more like 11-12 years.
« Reply #18 on: September 26, 2020, 19:35:23 »
well I took Michael's advice and reverse mounted the Germinar  67-52 step-down, BR-2a reversing ring to F-mount, Actus F-Mount board.
not too bad.. https://pbase.com/image/171070294
