Author Topic: AIS 28 2.8 and hood  (Read 1952 times)
Frode
AIS 28 2.8 and hood
« on: August 27, 2020, 09:31:24 »
Any experience using HN-1 (instead of the original HN-2) on the AIS 28 2.8?
I dont have a hood for mine, and I have a chance of buing one from a person nearby :-).
Re: AIS 28 2.8 and hood
« Reply #1 on: August 27, 2020, 10:37:43 »
HN-1 will be very short on an 28mm, it was intended for 24mm so will not supply adequate shade since Nikon is very conservative and always makes sure that evne if you fit filters under the shade they will not give mechanical vignette,,,
« Reply #2 on: August 27, 2020, 11:35:45 »
I think even the HN-3 (for 35mm focal length) will work with the 28/2.8, as long as it is fitted directly to the lens and not on top of a filter.
The HN-1 is short and will not provide much shade from bright light, but it will offer some mechanical protection from bumps and stray fingers.
« Reply #3 on: August 27, 2020, 19:55:57 »
This is my experience also.
Frode
« Reply #4 on: August 27, 2020, 21:22:57 »
Thank you all for your response, I think I’ll pass on this one then.
« Reply #5 on: August 28, 2020, 00:44:15 »
Or get the HN-2.
« Reply #6 on: August 28, 2020, 08:51:02 »
Buy the HN-1 - then you will have it for when you get the 24mm lens.   ;) ;) ;)
Luc
    • Flickr
« Reply #7 on: August 28, 2020, 11:42:25 »
From experience I can confirm the HN-3 works ok on this 28mm.
