Author Topic: APO EL Nikkor 105mm F5.6N and Nikon Z 6  (Read 4435 times)
Michio Akiyama
  • RED BOOK NIKKOR
    • redbook-jp.com
« on: August 02, 2020, 14:26:33 »
Hello Nikon friends,
A small but Big Optical Jet Engine
https://redbook-jp.com/redbook-e/rfap/ap3.html
Please enjoy and have fun!! Thank you!
Michio Akiyama/JAPAN
A member of NikonGear and Nikon Kenkyukai Tokyo
Nasos Kosmas
  • Athens, Greece
Re: APO EL Nikkor 105mm F5.6N and Nikon Z 6
« Reply #1 on: August 02, 2020, 15:37:28 »
Very nice thank you!
« Reply #2 on: August 02, 2020, 15:41:43 »
Love this lens. I also had the 210mm version, but sold it as it was cumbersome and no better than the 105mm version. I have the later APO El Nikkor 105mm version and use it on the Cambo Actus Mini view camera, usually with stacking. \
Here is one taken the other day as to what i do with it.
Michio Akiyama
  • RED BOOK NIKKOR
    • redbook-jp.com
« Reply #3 on: August 03, 2020, 05:21:39 »
This big lens is also nice.
APO EL Nikkor 210mm F5.6
https://redbook-jp.com/redbook-e/rfap/ap4.html
« Reply #4 on: August 03, 2020, 08:23:08 »
How would the above image of the yellow flower had looked like if the "normal" EL Nikkor 105/5.6 was used or one of the 105 Micro Nikkors?
« Reply #5 on: August 03, 2020, 09:31:27 »
Thank you for sharing yet another lens set on the Redbook! It has turned into quite a library ;) Very nice light in those images, crisp and clear!
« Reply #6 on: August 03, 2020, 13:02:58 »
Not as well corrected in my experience. And the APO El Nikkor 105mm F/5.6, IMO, has a certain style or quality that is pretty much unique IMO.
I have a good many APO lenses and, although each lens has it's qualities and use, few (if any) are quite as flexible and have the micro-contrast (or whatever we can call it) as this lens. And it is not even a fast lens!
« Reply #7 on: August 03, 2020, 21:57:46 »
From my darkroom time I have a good collection of enlarger lenses but none are "APO branded". But you would expect an enlarger lens to be a kind of "APO".
I looked in a Nikon Product Guide 1996 - 1998 but among the EL-Nikkors only the "standard" 105/5.6 was present. Apart from the 75/4 which is a 4 lens desogm all other in the guide are 6 lenses in 4 groups designs (double gauss?)
I can see that the APO 105 has got some "hype" as prices are in the high end. I will test my enlarger lenses and see if I really need the "APO".......I hope not.....
During my web search it seems the Printing Nikkor 150/2.8 is also a popular lens for close-up work.
Toby
    • Toby Marshall
« Reply #8 on: August 04, 2020, 16:07:10 »
It's worth noting that there are two different versions of this lens with slightly different specs. Both are 8 elements in 4 groups, but the N (new) version is slightly shorter (104.8mm) and has a slightly different distortion characteristic. I have the N version (It was $1200 mint and I couldn't resist) but stupidly, I have never really taken it out for a good spin. It does have an amazing kind of rendition, clean and with great microcontrast.
« Reply #9 on: August 08, 2020, 19:09:11 »
Had the AEN 105mm old and new, sold the old one, kept the new.
Also had the AEN 210mm + 300mm, but sold both as too heavy and bulky.
The 105mm is a tack sharp lens and a pleasure to use...
dickb
« Reply #10 on: September 03, 2020, 17:45:50 »
Well, Apo is mostly used to signify a better than usual colour correction, as ideally it should be corrected in a way that all colours focus in exactly the same plane. This is only needed for colour enlarging. I wouldn't expect most enlarger lenses to be highly colour corrected.
The APO EL Nikkors were always in the higher price range, as they were specialist lenses, I wouldn't qualify that as hype. If you look for a Printing Nikkor 150/2.8, be aware there are several versions, some of which have an image circle larger than full frame cameras, some smaller.
