Author Topic: August 2020  (Read 45384 times)
Re: August 2020
« Reply #210 on: August 28, 2020, 08:34:09 »
Looks like we're the two guys using that lens on this forum.
The argument for the Tamron is certainly its close-up ability.
Re: August 2020
« Reply #211 on: August 28, 2020, 14:02:42 »
August 28
Rosa @ wide open with
D850  Tamron SP 45mm f/1.8 Di VC USD
Re: August 2020
« Reply #212 on: August 29, 2020, 01:19:36 »
Cant see (or hear) what you're playing Jack ;)
Kraftwerk - Trans Europe Express
https://www.youtube.com/watch?v=XMVokT5e0zs
Good music to edit photos by.
Re: August 2020
« Reply #213 on: August 29, 2020, 07:25:52 »
Great album, Jack
Mini-fair in the city
Z6   Voigtländer | Septon 50mm f/2
Re: August 2020
« Reply #214 on: August 29, 2020, 10:33:00 »
34 degrees and lots of IR.
Re: August 2020
« Reply #215 on: August 29, 2020, 10:45:33 »
Nice!
Re: August 2020
« Reply #216 on: August 29, 2020, 10:57:57 »
Re: August 2020
« Reply #217 on: August 29, 2020, 11:21:22 »
Wilhelminabrug Den Bosch by night.
Z6  35mm f/1.8S
Re: August 2020
« Reply #218 on: August 29, 2020, 13:00:31 »
A totally failure generated in its wake something of interest nonetheless ....
I had carefully prepared a leaf section of Water Plantain Alisma plantago-aquatica to do a photomacrograph of the smut fungus Doassansia alismatis, which can be guessed from its name to target exclusively Alisma. I stained with Acridine Orange dye that should give some nice UV-induced fluorescence (UVIVF). So far so good.
The scene was captured with the Mitutoyo 10x/0.28 objective (infinity corrected, photographers would think of this as 21mm f/17 lens) on the Z7, using a Convoy UV-LED for illumination. I set up my Stackshot 3 rail for high resolution and shot 120 frames. All well, except i had forgot the backlash calibration of the macro rail, which was set 223 µm off. Thus my attempt of documenting the spore balls of this smut was a total failure as focus was off by a wide margin. Looking through the stack frames later, however, I found a few that had captured just a tiny part of the scene in tolerable focus (not the part of interest, though). I enlarged that small part of the frame using Topaz Gigapixel AI, and here it is. You can see the cell walls, cell nuclei some in meiosis (blue), stomata (those large cells looking a bit like female private parts), and the occasional dusting of spores (yellow). The dark stomata have already been invaded by the smut, but in an early stage as the local infection there had not developed into spore balls.
Thus a failure with visual benefits, after all.
Alien smut landscape
Re: August 2020
« Reply #219 on: August 29, 2020, 17:17:30 »
From today's shooting spree. Df, Summicron-R (50mm, Mk II) @f/8.
Re: August 2020
« Reply #220 on: August 30, 2020, 17:33:48 »
August 30
white rabbit
Z6  50mm f/1.8S
Re: August 2020
« Reply #221 on: August 30, 2020, 18:38:05 »
A white, lop-eared rabbit <3
Re: August 2020
« Reply #222 on: August 30, 2020, 19:03:37 »
Holland Lop is the breed. This female is 11 weeks the white will turn to grey in time.
Luc
    • Flickr
Re: August 2020
« Reply #223 on: August 30, 2020, 21:09:21 »
Evening scene at Station Haaksbergen/The Netherlands (Z6, iso 12.800)
Re: August 2020
« Reply #224 on: August 30, 2020, 21:16:36 »
Looks like you travelled back in time.
