Author Topic: August 2020  (Read 46667 times)
Luc
    • Flickr
Re: August 2020
« Reply #180 on: August 26, 2020, 16:01:36 »
August 25
Leaves, squash showing mineral deficiency
Z6  nikkor SC 50mm f/1.4
Vibrant image, I like it a lot.
Luc
    • Flickr
Re: August 2020
« Reply #181 on: August 26, 2020, 16:02:15 »
Peter all happiness in one photo!
My old Nikon 105/2.5  f2.5 1/200 320 ISO on Z50
Subtle, very nice.
Luc
    • Flickr
Re: August 2020
« Reply #182 on: August 26, 2020, 16:02:51 »
Hibiscus, August 25. Handheld Df, Nikkor 55/2.8 AIS @f/8.
Delicate, nice shot.
Luc
    • Flickr
Re: August 2020
« Reply #183 on: August 26, 2020, 16:04:07 »
The NEX-5N Monochrome with the Voigtländer 25mm f/4 Skopar SC is just small enough to go into my purse, so tends to accompany me on commuter train trips these days. A snapshot taken with the B+W 093 filter (IR) shows the good performance of the tiny 25mm lens.
Strong image, definitely snapshot+
Luc
    • Flickr
Re: August 2020
« Reply #184 on: August 26, 2020, 16:04:52 »
August 26
Wind
Z6  50mm f/1.4SC
Lovely subtle color palette.
Re: August 2020
« Reply #185 on: August 26, 2020, 16:47:48 »
shot of genious
Re: August 2020
« Reply #186 on: August 26, 2020, 17:15:25 »
Olives, grown in Northern France in a garden (mine) that is facing North. Df, 55/2.8 AIS (@f/8 IIRC)
Re: August 2020
« Reply #187 on: August 26, 2020, 19:54:39 »
A sharp lens, the 55/2.8 Ai-S.  You like it?
Re: August 2020
« Reply #188 on: August 26, 2020, 19:55:17 »
Window view
Z7  105/1.8  Ai-S
Re: August 2020
« Reply #189 on: August 26, 2020, 22:27:34 »
Yes.
Partly for sentimental reasons, as this lens was hailed (in France at least), by the mid-eighties, as one of the best standard lenses ever, and an alternative to the more conventional 50/1.8.
I've been using it every now and then since about 2012, on the D800 where it does not disappoint, then on the Df but less often, as I bought a Zeiss planar 50/2, then a fresh second hand Milvus version of it (with vastly improved coatings).
The Zeiss 50/2 Milvus seems better in every respect, and has become one of my most frequently used lenses. However the older Micro Nikkor is a solid performer in every respect too, is lighter, and I got a matching extension tube. I used it a lot with my OM-D for macros.
The only real drawback of the Micro Nikkor is its tendency to flare, so I won't call it an allrounder. Same with the Summicron-R 50/2 for instance, which is insanely good (two lanthanum elements inside may partly explain that...), but for the coatings. Coatings have been improved a lot since the late seventies / early eighties. Otherwise I do not have marked preference for recent prime lenses compared to older optical formulas.
Re: August 2020
« Reply #190 on: August 27, 2020, 13:11:09 »
Just coming back from vacation time. Have been away with the d200 ir and 18-70mm without a card reader to put the images in the computer and now the hard disk is broken so it will take a few days before I can process them. Wonderful time in the coast of Cádiz, south Spain, moving between Conil, El Palmar, Caños de Meca, Barbate and Zahara de los Atunes and La Muela throwing in Vejer de la Frontera for good measure. A true paradise for me. Best company too...
  I had a lot of images and stories to go through in the forum. Thank you all for making this place so special.
   Flying free. D200 ir, 18-70mm
Nasos Kosmas
  • Athens, Greece
Re: August 2020
« Reply #191 on: August 27, 2020, 13:34:54 »
Paco when you post somenthing I feel that my posts are so ordinary :o
keep on
Re: August 2020
« Reply #192 on: August 27, 2020, 13:36:35 »
Peace in the troubled sky...
Re: August 2020
« Reply #193 on: August 27, 2020, 13:56:49 »
keep on
  Please, don't. I use to feel that way and have had to learn not to criticise or compare myself. Still working on it  ;D  The sharing is the point here for me.
   Thanks a lot for the appreciation.
   Akira, that image is engaging but the panorama!!!
Re: August 2020
« Reply #194 on: August 27, 2020, 14:02:01 »
Thank you, Paco.  Actually, the same rainbow was captured in that pano posted in the dedicated section, but this was processed more for the rainbow.
