Author Topic: Focus distance information in EXIF data  (Read 1940 times)
Kim Pilegaard
  • "Nikea"
« on: July 22, 2020, 17:43:48 »
From the EXIF data it is possible to extract information on Focus Distance. Does anyone know how this information is derived and how precise it is?
Kim
Re: Focus distance information in EXIF data
« Reply #1 on: July 22, 2020, 19:21:01 »
There is a mechanically based read-out in the lens. Probably not very exact, as far as I can evaluate the numbers seen in my EXIF headers.
It would be easy to set up a controlled experiment to learn the accuracy, however.
Kim Pilegaard
  • "Nikea"
« Reply #2 on: July 22, 2020, 21:51:29 »
Thanks for your answer, Birna.
Yes, I also thought to make a test with different known distances, but maybe someone already did that.
It seems from the results, I get, that it is not a continuum of distances, but only a specific set of distances (probably lens specific) is registered.
When for instance you photograph birds, it is nice to know the actual distance. It can also be worked out form a lens formula if you know the size of the bird.
Kim
« Reply #3 on: July 22, 2020, 22:36:34 »
The contraption inside the lens is a contact "finger" that slides across a print with intermittent gaps. So yes, the distances are "zoned" and probably specific to a given lens.
