Author Topic: Zoom-Nikkor 35-70mm f/3.3-4.5 Ai-S!  (Read 4554 times)
Re: Zoom-Nikkor 35-70mm f/3.3-4.5 Ai-S!
« Reply #1 on: July 05, 2020, 05:11:48 »
"Having said that, you can still buy one of these new when sold with new-old-stock Nikon FM10s or Nikon FE10s"
A small correction - the lens sold with the Cosina-made FM10 and FE10 is a 35-70/3.5-4.8. It is a different lens which is a little slower at the long end. It looks more plasticy overall, has no chrome grab-ring, and it has only 6 aperture blades instead of 7. I've not tried this lens so am not sure how it compares optically with the older lens.
« Reply #2 on: July 05, 2020, 05:40:00 »
Thanks for clarifying!!!!
man, i am confused by these 2 lenses :o :o :o
« Reply #3 on: July 05, 2020, 22:51:17 »
"the lens sold with the Cosina-made FM10 and FE10 is a 35-70/3.5-4.8. It is a different lens which is a little slower at the long end"
It's also slower at the wide end - f3.5 vs f3.3, so overall about 1/6 stop slower through the entire zoom range.
I had the AI-S 35-70/3.3-4.5 for a while some years ago. I bought it second hand, the shop had two, one showed focus shift when zooming, the other was better so I bought it. I took some good pictures with it but felt it was never quite as sharp as my AI-S primes so I sold it again.
« Reply #4 on: July 06, 2020, 01:46:57 »
mine has terrible focus breathing :o :o :o
not sure about the focus shift. it can be tough to adjust a zoom back to factory standards. my guess is that it has been repaired.
« Reply #5 on: July 06, 2020, 06:54:13 »
Thanks for the write up, Richard.
This lens is not bad at all indeed and can give very satisfying results. The first AF version is of the same quality
« Reply #6 on: July 07, 2020, 15:49:43 »
Hello, does it have the same optical formula? :o :o :o
« Reply #7 on: July 07, 2020, 16:20:05 »
Yes, probably
