I received the lens today. The Dandelion chip will be here Friday.
Having examined the aperture stop-down mechanism of the Adaptall-2 N/AI mount, I have serious doubts whether its movement is linear with respect to aperture area. When I move the stop-down lever slowly and evenly with my finger, the diameter of the aperture diaphragm changes in a linear fashion. This is in contrast to an AI-S lens, in which the area of the aperture changes linearly.
I'm 95% sure about this, but the true test will come when I install the Dandelion and try to use the camera to control aperture. I find myself actually a bit reluctant to do the necessary surgery on the mount to make room for the chip, because I believe that camera control of aperture won't work right with this lens. However, even if it doesn't, the Dandelion will still provide the other benefits, such as obviating the need to use Non-CPU Lens Data, so installing the chip won't do any harm and will do some good in any event.
Having the chip identify the lens will be great because, as I discovered tonight, the Non-CPU Lens Data feature doesn't allow you to enter a focal length of 90mm!
Anyway, I've had a little time to play around with the lens, and I must say, this lens is unreasonably sharp. It's possibly the sharpest lens I've ever used at f/2.8. I'm actually flummoxed that a $125 lens dating from the late 1970s or the 1980s could be this sharp. Also, its field is extremely flat, even at non-macro distances. Evaluation of other qualities, such as contrast and color, will have to wait.
I'll report again once I've installed the Dandelion, but I'm not hopeful about that.
