Author Topic: Your experience with speed boosters/focal reducers/accelerators  (Read 2522 times)
Zang
Hi all,
What is your experience with those devices I mentioned? I refer to the names as generic equipment class, not any specific makers. Optical design is not an easy task and I am a bit surprised by claims that the boosters have next to none sharpness impact, especially when they are designed to accommodate a vast number of lenses that they can be used with.
Zang
HaraldH
I use a Viltrox 0.71x Nikon F to m43 adapter. I have not done any systematic investigation, but I have not noticed any adverse impact on resolution compared to a 'plain' K&F adapter. I have used a variety of Nikkors: 24 mm /2.8 'K', Nikkor-S 5 cm/2, 55 mm/3.5 micro, 105 mm/2.5 Sonnar type and Nikkor Q 200 mm/4.0.
I am not an optical engineer, but I suspect it is easier to design a 'one solution fits all' focal reducer - not changing the designed register distance by using the available space that normally is occupied by a flapping mirror - than it is to design a conventional teleconverter.
Note also that a 0.71x converter for m43 still cherrypicks the central portion of the image circle and crops out the often more troublesome original image circle periphery.
Of course, a plain m43 adapter crops away even more of the image circle periphery. But then keep in mind that a 16 MP m43 sensor has a pixel spacing comparable to a 64 MP full frame sensor. I don't think all Nikkors will have resolution like that.
David Thorpe claims a focal reducer even increases resolution:
https://youtu.be/qGIkq8b2iwg
Issues common to Viltrox 0.71x and K&F m43 adapter are that the lenses focused beyond infinity. The Viltrox has moveable optics, enabling adjustments to achieve infinity focus. The K&F has no such mechanism, but I guess it may be shimmed.
Harald
Toby
    • Toby Marshall
I did some investigation of the performance of Canon lenses on a Metabones speedbooster on a Sony A7RII. I was very surprised with the results, in that I could detect no degradation of the image in the center of the frame and very minimal softening at the extreme edges. Of course the Metabones costs about $500, and I'm sure the cheaper ones do not perform as well.
I did some pretty extensive shooting with a Metabones Speed Booster and the 50mm f/1.2 Nikkor on a Panasonic GH-2 and found the results surprisingly good. One of the captures was used for a double-page spread with no complaints from the customer.
Peter Forsell
  • A Cunning Linguist
Re: Your experience with speed boosters/focal reducers/accelerators
« Reply #4 on: June 03, 2020, 10:21:46 »
The speedbooster works just the opposite. It takes the larger image circle and squeezes it into a smaller image circle with higher light intensity. If the edges are troublesome, with a booster they are included, without they are cropped. What you described was how teleconverter works.
« Reply #6 on: June 03, 2020, 10:52:29 »
The 0.71x speedbooster is the inverse of a 1.4X TC. The first adds a full stop, the latter makes the master lens 1 stop slower. The "speed" change is just a consequence of the corresponding decrease or increase in focal length, respectively, as the actual aperture size stays the same.
HaraldH
« Reply #7 on: June 05, 2020, 17:51:01 »
I guess I was not entirely clear. The net effect of a lens designed for full-frame and a 0.71x speed booster - on a m43 sensor - is stil a crop of the original full frame image. But less of a crop than without the speed booster.
A 0.5x speed booster will condense all of the full frame onto the smaller m43 sensor.
