Author Topic: Is that a crappy lens?  (Read 14218 times)
Re: Is that a crappy lens?
« Reply #15 on: August 02, 2015, 22:38:53 »
Huh ? that was unexpected. Well, I have had an old, and rather small, 15mm Zeiss lens (F-mount, f/3.5 or f/4) in hands that could not even get sharp at any aperture, maybe a faulty copy. This one was even less expected.
« Reply #16 on: August 02, 2015, 23:01:13 »
Well, what shall I say, comversion is not always straight forward and sometimes needs s lot of thinking and dinkering around ;-)
« Reply #17 on: August 03, 2015, 00:31:26 »
OK. You posted a few very intriguing photos taken with a mystery lens. So what is the point?
Who in the first place said that the lens is crappy?
And: Who does  not know that a good photographer can take a good photo with any lens?
« Reply #18 on: August 03, 2015, 02:25:00 »
The flower shots are rather pretty.  The rainbow-colored bokeh fringe of the toad shot looks peculiar.
Is it only color corrected for UV?  Apparently the lens has no aperture.
« Reply #19 on: August 03, 2015, 02:29:38 »
If the 15mm is "small" and not like the Distagon 15mm for Yashica/Contax, it should be a rangefinder camera lens.  Then it wouldn't focus properly when mounted on a Nikon (D)SLR.  Maybe the focal point is "in" the lens.  You would have had to reverse-mount the lens for larger-than-life size shooting.
« Reply #20 on: August 03, 2015, 07:29:13 »
Well, the frog shot was mentioned to be stopped down, so it must have one and it does; to f11 actually.
And yes, it is color corrected UV-VIS.
« Reply #21 on: August 03, 2015, 07:30:10 »
Just bragging of course ;-) And I'm quite convinced you know what a "rhetorical question" is...  ;)
« Reply #22 on: August 03, 2015, 07:33:50 »
A stopped down shot (f8), here science related... European Starling VIS (left) and UV (right) showing intense UV patterns of the full ornate male plumage. Focus difference: None
« Reply #23 on: August 03, 2015, 08:57:08 »
I guess it is corrected for UV, not the visible range.
« Reply #24 on: August 03, 2015, 09:01:33 »
As I do not know your style I did not see the irony.
Is that a Microscope lens or a stepper lens?
What was the original intent and mount?
« Reply #25 on: August 03, 2015, 12:54:44 »
klaus-- could we see a better shot of the lens so we can read the lettering?
« Reply #26 on: August 03, 2015, 14:17:19 »
I mentioned that already above: "And yes, it is color corrected UV-VIS. "
It is all there Bob, nothing more (except the supressed serial number, as my lens pictures gets stolen for auctions at times)
« Reply #27 on: August 03, 2015, 14:54:52 »
maybe its me.. but i can't see the FL=? also UV-PL  ?
i don't need the serial number.. just intellectual curiousity
« Reply #28 on: August 03, 2015, 16:24:58 »
Planar = Pl
Focal Length is 62mm
« Reply #29 on: August 03, 2015, 17:31:54 »
For a certain time when Zeiss West was in legal battle with Zeiss East (Jena), they were not allowed to use the product names.
OPTON = ZEISS (West); UV-PL = UV-Planar; focal length f=62mm
That lens was made based on NASA requirements for extraterrestrial use (= space use), so it is an "extraterrestrial lens"  :)
It was intended to be used on Graflex and Hasselblad camera bodies. Mine is a prototype with a 67mm screw mount.
It has 11 lens elements in 11 groups (11e/11g), made purely out of synthetric CaF2 (calcium fluoride) and quartz (fused silica)
without glued elemnts to allow for flat transmission down to 200nm. So far I could find out about it until today...
Hope that satisfies your curiousity  - and also yours Frank  ;) ;) ;)
