Author Topic: Voigtländer Septon 50/2 on Nikon DSLR  (Read 13226 times)
Re: Voigtländer Septon 50/2 on Nikon DSLR
« Reply #15 on: April 28, 2020, 08:27:02 »
I was on full manuel mode. Think it is the only way I could get D5200 to work with lenses/adapters with no contacts. So I used the histogram to check exposure. Sometimes it is quite nice to be in 100% control like in the old days. Z50 came yesterday. In the documentation for FTZ adapter they write that non-AI lenses are not compatible and they may destroy contacts. I can't see the reason for that as the difference between AI and non-AI lenses in general is not what is inside the adapter which could damage the contacts. Then they mention some very old lenses by name which is incompatible. But a non-AI 50/2 works as good as AI'ed version of same lens as I see it without having tried it out other than non-AI lenses mounts nicely. The body will not see any difference between the two. I have noticed a small black switch on the F-side of the adapter which is placed just outside the mount and can see if I mount a more modern lens like AFD 85/1.4 this switch will be activated. But no difference between older non-AI/AI. I assume that stop down exposure method is used for both types of old lenses like I do now with Septon on D5200 via an adapter.
I find it difficult to use live view. The sunlight can cause that it is difficult to see what it going on and I can hold camera more steady using optical finder. So look forward to use Z50.
Arri
« Reply #16 on: May 16, 2020, 08:33:20 »
The Septon is a gem, I call three of it my own and use it with the F4 and D700.
It is excellent for B&W use and I like the Bokeh of it.
BTW: all Voigtländer lenses for the Bessamatic sytem are good usable lenses, very interesting is the Zoomar 36-82 f/2.8
I love the lens destorsions of it :o
« Reply #17 on: May 16, 2020, 08:50:55 »
The Septon 50/2 is not bad.  The Color Ultron 50/1.8 is much much better.
Arri
« Reply #18 on: May 16, 2020, 08:56:00 »
This is an analouge cyanotype print copy of a digital image I made with the Septon lens. Self coated Fabriano water colour paper.
« Reply #19 on: May 16, 2020, 08:57:06 »
Nice colours too?
Arri
« Reply #20 on: May 16, 2020, 09:35:41 »
Nice colours too?
For analouge film the colours nice, in digital use it has colour shifts. I use it in B&W only
« Reply #21 on: November 02, 2025, 23:03:04 »
On the Zf and posted in the Daily November 2025
« Reply #22 on: November 03, 2025, 07:52:13 »
The Septon works great on the Nikon Zf.  Here two interior shots. Despite it's 90cm minimum focus distance..  (the last picture is obviously cropped)
« Reply #23 on: November 03, 2025, 08:20:20 »
The Septon is a nice lens. I have not tried it yet on my Z50.
It can make some nice "portraits" of Rembrandt paintings?
« Reply #24 on: November 03, 2025, 16:21:24 »
Yes.  It's a very sharp lens. Little distortion and LoCa.  Weaknesses are flare and vignetting
« Reply #25 on: November 03, 2025, 16:27:19 »
Flare and Vignetting 'in action'  ;)
« Reply #26 on: November 04, 2025, 00:02:15 »
It is a sharp lens. I just put it on my Z50 with DKL to F adapter + F-Z adapter.
I took a test image at closest focus distance stopped down a bit.
Picture attached + 100% crop.
I will try it one day for real images. It also has a pleasant bokeh. It has 52mm filter adapter so I have plenty of shades that will prevent flare :-)
I have wondered why the Summicron for Leica R (50/2) are sold at rather high prices like 300 Euros.
Can it do something the Voigtländer Septon or Ultron can't do?    ......or even the Nikkor-H 50/2?
« Reply #27 on: November 04, 2025, 08:11:17 »
The Nikkor AI 50mm f/2 is the best one.
« Reply #28 on: November 04, 2025, 08:17:43 »
Except its bokeh. Sexangular  point lights are ugly.
« Reply #29 on: November 04, 2025, 08:28:10 »
That's true. Most 50/2 lenses are not perfect in the bokeh-department ;)
