Author Topic: Nikkor 28mm f2.8 AIS vs f3.5 AIS (or late AI) at moderate distance  (Read 4728 times)
Zang
Hi all,
To those who have tried the lenses, how do they compare at the moderate distance let say of 3 to 5 meters?
Zang
Re: Nikkor 28mm f2.8 AIS vs f3.5 AIS (or late AI) at moderate distance
« Reply #1 on: February 22, 2020, 20:27:22 »
I currently lack a copy of the 28/3.5 (late) to make a up-to-date comparison, but between the two lenses, the "sharpness" performance of a good copy of the 28/2.8 AiS is going to be hard to beat, especially if you need to shoot at wide open or other wider stops. The non-CRC Nikon 28's (early 3.5, earlier 2.8, late 3.5) all seem to follow a pattern of acceptable sharpness in the center that noticeably drops off towards the outer zones.  Stopping down helps, but does not completely eliminate the sharpness falloff.  The 28/2.8 AiS maintains the apparent center sharpness much further out to the edge of the frame. Others may have a different experience.
Zang
« Reply #2 on: February 24, 2020, 05:17:18 »
Thanks Keith. I read about 28mm f2.8 being stellar at close focus but average at long distance. My guess is, for a wide angle lens, long distance means 3 meters and up :)
« Reply #3 on: February 25, 2020, 23:45:55 »
My copy of the 2.8 AiS is great at 1 foot, 1 meter, 10 meters. It develops a problem at infinity by rendering a blob of blur just to the left of center--roughly about ten percent of the frame.  But this is ONLY at infinity!  As soon as you pull the focus closer, like 50 meters, the blur zone goes away!  I checked a friend's copy and it behaved exactly the same.  Also, the 2.8 AiS is so sharp at the wider apertures that the slight softening by diffraction at the small apertures like f/11 and f/16 is quite noticeable.
Chip Chipowski
« Reply #4 on: February 26, 2020, 04:35:04 »
I have the 28mm f/3.5 K version that I got on recommendation from BR - I have no comparison to other models but I really like the shots I get with that lens
« Reply #5 on: February 27, 2020, 04:02:18 »
That's a great old lens.  Classic drawing of the image.
