Author Topic: Adapter thread. The new Lords of the Rings.  (Read 59647 times)
Re: Adapter thread. The new Lords of the Rings.
« Reply #90 on: May 13, 2020, 10:00:03 »
I believe so. At least I've seen some on eBay.
I made my own based upon Amadeo for E-mount.
« Reply #92 on: May 13, 2020, 14:38:10 »
Thank you all.
« Reply #93 on: May 13, 2020, 14:54:33 »
I am still undecided which OM to Z adapter is right for me.
Novoflex is a safe bet for 120€, K&S receives mixed reviews for 50€ and there are plenty of cheapo fabrications with no reviews at all. Stuck here.
« Reply #94 on: May 13, 2020, 16:37:38 »
I suggest you start with a cheap one, just to get going with the OM lens on your Z6. If you find using that lens a pleasure, consider getting a quality adapter.
Congrats with your entry into the Z world, by the way.
« Reply #95 on: May 13, 2020, 18:51:31 »
Hi Bent !
Just for help :
https://www.amazon.co.uk/Camera-Adapter-Nikon-Rangefinder-Mount/dp/B07VJ2YKXT
Do note this adapter is only intended for Nikkor rangefinder lenses with external bayonet. Not suitable for the rangefinder normals 50mm/5cm lenses.
The quality of the adapter is quite good, though. I have several of them.
« Reply #96 on: May 14, 2020, 00:01:16 »
Good to know, Birna ! Thanks.
To be honest, I didn't know they were 2 different mounts.
« Reply #97 on: May 14, 2020, 00:27:39 »
I was aware, and I was looking for one for the internal, but more of curiosity. I do not have anything to fit yet ;)
« Reply #98 on: May 14, 2020, 00:47:52 »
I ordered the K&F to check it out. It will arrive this week and if I do not like it, I will return it and get the Novoflex ... Then I try to rid my father from his Zuiko Collection ...
« Reply #99 on: May 14, 2020, 05:48:57 »
 ;D  ;D  ;D
« Reply #100 on: May 14, 2020, 08:39:06 »
The internal S-mount for the 5cm/50mm normal lenses was a heritage from the Contax camera. This allowed the lenses to be very compact as they had no helicoid of their own. You focused them using the internal helicoid of the camera. For shorter or longer focal lengths there was an external S-mount.
Here are examples of two Nikkor normal lenses 5cm f/1.4 (late '50s) and the reborn 50mm f/1.4 Millennium (a refined version of the 'Olympic' model from 1964), plus the Voiugtländer 50mm f/1.5 Nokton (ca 2000). The latter uses the external mount and thus has its own helicoid for focussing.
The adapter for Nikkor-S (external) to Z can be found easily, although not all have the accuracy to bring the lens to infinity. The focusing adapters are quite rare yet do exist. One shown here is actually a makeshift one purchased from eBay and turned out to be a clever hybrid between a Leica L-Nikon Z and a hacked helicoid probably from a Russian  clone of the Contax. The other is my own remake of the Amadeo focussing mount for Nikkor rangefinder normals to Sony E, which I managed to recast with a factory Z bayonet to be Nikkor S to Z. I reserve it for the 50mm Millennium Nikkor.
« Reply #101 on: May 14, 2020, 19:26:43 »
The small adapter DKL - (Bessamatic)  to Nikon F.   (The adapter is the small black ring with the aperture value's)
The lens is the Voigtlander Septon 50mm f/2
« Reply #102 on: May 14, 2020, 19:28:55 »
You need an additional F to Z adapter, or is there any direct adapter Bessamatic-Z?
« Reply #103 on: May 14, 2020, 19:36:22 »
Yes you need an extra adapter as there is no direct one. I chose  the Nikon-F because you can use FTZ for better EXIF data.  With all other adapters you can only use the the comments- field to store lens -information on the Z camera's images.
« Reply #104 on: May 14, 2020, 19:44:10 »
The B4 (TV Broadcast lens) adapter to Nikon Z.  You can connect a variety of B4 broadcastlenses on the Nikon Z's.  It is necessary these B4 lenses have a doubler (double the image-field (and aperture value) otherwise they will not fill the sensor. High resolution lenses are better.  You can shoot film in the DX mode with minimal vignetting at the wide settings.  My experience is these lenses are not ideal for stills, but better be used for film only.
The adapter has it's own tripod-foot to mount the Broadcast lens.
