Author Topic: Rose Robin  (Read 2029 times)
Bear Dale
Rose Robin
« on: December 08, 2019, 04:15:41 »
Rose Robin
Scientific Name: Petroica rosea
Re: Rose Robin
« Reply #1 on: December 08, 2019, 05:20:44 »
Wow, your bird shots are superb! Lovely colours and soft muted background. You obviously have a long lens and know how to use it well.
Bear Dale
Re: Rose Robin
« Reply #2 on: December 08, 2019, 07:39:50 »
Thanks Roland, I have the 200-500mm which is sold by Nikon as a budget tele zoom. Its nowhere near the price of a 500mm or 600mm F4, which I lust after!
Re: Rose Robin
« Reply #3 on: December 08, 2019, 15:10:21 »
Awesome image
You do really, really, well with the 200-500
Bear Dale
Re: Rose Robin
« Reply #4 on: December 09, 2019, 05:35:10 »
Awesome image
Thank you Armando
Re: Rose Robin
« Reply #5 on: December 10, 2019, 04:39:29 »
Do you find it useful to have a zoom, or do you almost always shoot at 500mm? If so, the 500PF would be worth looking at - it is much more expensive than the 200-500, but considerably cheaper than the 500 and 600 f/4 lenses, and much more portable. It is optically a step up from the 200-500, although your pictures shows the zoom is very good.
I still have my ancient AI 400/5.6 ED (not IF), it is very sharp - when focused properly, difficult for subjects like birds.
Bear Dale
Re: Rose Robin
« Reply #6 on: December 10, 2019, 05:42:42 »
G'day Roland, I don't think there's an article on the 500PF that I haven't read, twice :)
I am so close to ordering one, I do use less than 500mm, but looking through LR, not very often.
Re: Rose Robin
« Reply #7 on: December 10, 2019, 22:20:19 »
Not sure what camera you use, but if you shoot a high-res FX camera, you can "zoom" a little by cropping.
(I'm guessing with small birds you usually want to zoom in rather than out :) )
A couple more of points on the 200-500 vs 500PF:
The 200-500 focuses to 2.2m, giving 1:4.5 magnification, the 500PF focuses to 3m giving 1:5.5 magnification. Both focus pretty close for this focal length but the zoom obviously does better here. I guess you are usually shooting at much greater distances so this may not be very relevant.
The 500PF is slightly shorter than the zoom @200mm, and significantly shorter than the zoom @500mm, so should be easier to transport and more agile in the field. It's also only 2/3 the weight although if you shoot from a tripod that may not be much of an issue.
All the best with your decision!
Bear Dale
Re: Rose Robin
« Reply #8 on: December 10, 2019, 23:33:16 »
Thanks for the information Roland, appreciated.
