Author Topic: New-Nikkor 20mm f/4 Repair!!!  (Read 4935 times)
Re: New-Nikkor 20mm f/4 Repair!!!
« Reply #1 on: November 27, 2019, 02:16:57 »
Nice job, as always, Richard!
I loved this almost-pancake on my D750.  The only drawback was that the OVF was a bit too dark even just to compose in dim conditions.  Otherwise, it was an optical gem.
« Reply #2 on: November 27, 2019, 08:35:37 »
Thanks for the write up, Richard.  It sure is a great lens.
More info on the 20/4  https://nikongear.net/revival/index.php?topic=1105.msg107308#msg107308
whatdoido
  • You ARE NikonGear'23
« Reply #3 on: January 31, 2026, 15:06:40 »
I attempted a repair on an AI copy of this lens (which was pretty much identical to Rick's K writeup) and I found it very difficult - the focus ring collar could not be removed, with no amount of heat, acetone, IPA nor tapping would free it.  Exactly the same with the lens objective and the front optical group.  For the barrel I had to file an angled groove (so the front face was still intact) to get enough clearance to get a driver onto the screw head and to remove so I could at least service the helicoids.
What I also found - at least with this copy - was the focus is heavy. once the lens objective is put back into the barrel;  after I serviced it was smooth but as soon as the lens objective is inserted (which was a very snug fit), the focus action becomes heavy but not binding.
On a FB, one lens tech said all copies he's worked on have been tight.  Its a shame that this lens is glued like this as its a nice little lens.
whatdoido
« Reply #4 on: May 04, 2026, 20:56:39 »
I finally managed to service my copy of the 20mm f/4 - and I had a much tougher time than Ric.  Experiences shared
https://whatdoineed2do.blogspot.com/2026/01/widely-regarded-nikkor-20mm-f4-ai.html#servicing
Servicing this is an utter pain - i've had 2 copies of the K (103xxx and 106xxx serial numbers, with Roland data saying the first one was 1030001) and they're both sealed so well its like they didnt think these lens would need to be ever opened again.
The focus ring retaining ring does come off and I had to file slots behind the ring to get to the focus ring screws and the lens objective needs the strength and torque of all humanity to unseat. BUT its done - i finally got in and was able to save these 2x lens from a life in a junk bin.
TLDR: its hurts, dont do it unless you have the tools and know exactly what you're doing - you'll damage a beautiful little lens and its not worth it
