Author Topic: MF Nikon 20mm UD, non Ai, (Help with cleaning a fogged element)  (Read 2400 times)
Steven Paulsen
  • Cumpulsive Tinkerer
Auction site, "Clean, perfect glass." (I even asked the seller to open the aperture to 3.5 & shine a small flashlight up through the bottom element & check for defects.)
I received the lens. The outside is simply pristine. From the mount and looking at the aperture tab, it looks near brand new.
The bad; The inside of the front element is fogged, maybe old condensation, not quite the normal spider web, fungus look.
I an not a Neophyte. If not excessively expense, where can I send it to be cleaned?
(Or)
Can anyone give/show me a tear down procedure to pull the front element assembly and do it myself?
I wanted a 20mm for my Df. (OLD SCHOOL)Just set the HF distance on the lens barrel & shoot away. 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)
Re: MF Nikon 20mm UD, non Ai, (Help with cleaning a fogged element)
« Reply #1 on: September 13, 2019, 03:08:55 »
im going to write one this month (or next month) :o :o :o
Steven Paulsen
« Reply #2 on: September 13, 2019, 05:39:00 »
Please Hurry. I have a limited return window. Is it brain surgery?
I like the old UD design because of the long focus throw. Put infinity @ F8 slash mark & forget about it.
« Reply #3 on: September 13, 2019, 05:45:12 »
The AI 20/4 also has a very long focus throw at 140°, and much more compact than the UD.
The AI 20/3.5 isn't too bad either at 100°
The AI-S version is a bit short at 70°
« Reply #4 on: September 13, 2019, 09:01:53 »
really busy at work now. my blood pressure even shot up this morning :o :o :o
just return it
« Reply #5 on: September 13, 2019, 14:27:37 »
 :o :o :o
« Reply #6 on: September 13, 2019, 15:51:12 »
Your blood pressure dropped a few notches, Rich? The illustrations of how to access the inside of the front element should be quite self-explanatory. Thanks for providing such insights into the workings of our Nikkors, old and new.
« Reply #7 on: September 13, 2019, 17:02:48 »
thanks, i had 2 cans of coke :o :o :o
i get easily irritated at work ::)
preparing this one at the moment
Steven Paulsen
« Reply #8 on: September 13, 2019, 23:29:14 »
I unscrewed the narrow pin on the side of the "Hood."
Then unscrew the nameplate ring?Then remove the outer hood, filter holder?
OTOH, I started a return for the 20mm UD & purchased a non-Ai F4, 20mm.
'That Auction Site" has turned into a generation of people who know nothing on condition, poor packaging. Yes, the dealers are holding common ground. I actually received a Nikon 12-24. shipped 3000 miles, (No padding) in a paper/poly business envelope. (It survived.)
This is part of my insanity trip into completing an old school carry sack for my Df. (All Nikon MF primes from 20mm - 300mm.)
(Is there an old folks home for Photographers?)
