Author Topic: Nikkor 105mm f/1.8 Ai-S  (Read 13808 times)
Re: Nikkor 105mm f/1.8 Ai-S
« Reply #1 on: August 30, 2019, 14:20:12 »
It seems we both like this lens...
I often use it for stage shots (theater, concerts), sure not because of the max aperture (performance is not that good), but because it will gracefully take spot lights in the frame without annoying artifacts or contrast drop. The 105/2.5 might be equally good in that respect, I did not compare them from that point of view lacking time & opportunities, but I know I can rely on the 105/1.8.
« Reply #2 on: August 30, 2019, 19:59:25 »
Great review and article, Rick.  I love this lens too.  It's true;  close up is a little bit of  weak point of the lens, for that reason Close-up lens T6 does not give excellent results. But indeed, it was designed as a portrait lens, very strong in that distance, I think.
« Reply #3 on: September 14, 2019, 22:01:41 »
Glad to see you got your hands on a 105/1.8 and documented it.  One of the lenses I will never go without.
« Reply #4 on: September 14, 2019, 23:04:14 »
Thomas Stellwag is, apparently, another fan.
