Author Topic: Easy way to use Tamron/ Sigma Tap in Console  (Read 3439 times)
Pistnbroke
« on: August 09, 2019, 09:02:02 »
I have the Tam 100-400 and you need 15  focus adjust figures to input to the lens. Now if you use a ruler or similar this takes for ever.
On the D850/500/750 you have automatic fine focus adjust so in 15 min you can do all the distances/focal lengths required using the auto system and input them to the tap in console . Makes a big improvement for the close up end particularly 400mm which you might use for macro.
Set camera at 0  once the lens has stored the figures. While I have not tried it don't see why you cannot use this with the sigma console for sigma /Nikon compatible (G2 etc) lenses
Hope this helps someone ..if its common knowledge sorry.
