Author Topic: HTTPS: Please report any issues in this topic.  (Read 137567 times)
Re: HTTPS: Please report any issues in this topic.
« Reply #150 on: September 26, 2019, 14:49:11 »
I don't find where I can accept the risk and click that. I am on a PC with Chrome browser. Any help appreciated. Otherwise, my every keypress initiates all of this bothersome stuff.
Bear Dale
« Reply #151 on: September 26, 2019, 14:51:00 »
Click on
I understand the risks and wish to continue
Hi Fons, I have been doing that, but I have to do it each time I come back to NG.
Is there someway to accept permanently?
« Reply #152 on: September 26, 2019, 15:02:59 »
A detailed procedure was mentioned in this thread,
simply log out of Nikongear, clear browser caches,
a program like CCleaner will easily take care of that, restart and log in to Nikongear.
Michael, cleaning browser history and clearing the cache within Chrome shall not be all that different.
« Reply #153 on: September 26, 2019, 15:12:44 »
I am still bothered with this at the top, goes away, and then it shows again :o
« Reply #154 on: September 26, 2019, 16:58:48 »
The DB corruption message is the one that should be displayed. The fact you see different sometimes is an indication the data stream to your browser is being cached here and there. Old stuff might prevail and not being properly flushed from the caches.
Bear Dale
« Reply #155 on: September 27, 2019, 01:49:29 »
Thanks done.
Luke Miller
    • Luke Miller - Photographer
« Reply #156 on: September 28, 2019, 18:04:48 »
I get certificate errors with all my browsers.   All offer a "proceed anyway" option (Edge, Chrome, Internet Explorer and Firefox). But no way to make that "sticky" that I have found.
Matthew Currie
« Reply #157 on: September 29, 2019, 04:05:42 »
I put in a security exception for Firefox, which seems to be sticking.
Bear Dale
« Reply #158 on: September 29, 2019, 08:40:01 »
Could you please be so kind to explain how one does this?
I cleared the cache and that worked for a little while, but now the warning has returned :(
arthurking83
« Reply #159 on: September 30, 2019, 01:10:42 »
Try this:
In FF, go to the options page(small gear looking icon).
In the Options page, on the left hand side, click on privacy & security. Scroll down to bottom and look for the certificates area.
Click the [View Certificates] box, which will pop open a new sub-window.
There are 4 tabs across the top, click on the Servers tab.
You will then see a list of certificate servers, scroll down to find the one labelled:
"Secticgo Limited ..... *.accountservergroup.com ..... nikongear.net:443"
If it's not listed, then at the bottom edge of the window is a button to create an exception.
When you click on it, it will open a dialogue box with https:\\ already set, you add in nikongear.net to complete the address field.
One of a few things may happen:
If the nikongear certificate is listed in the server list, it may already be valid and verified .. so no need to do anything.
(this is what mine says now)
If for some reason yours doesn't show the certificate valid, then on entering the required data, the add exception box should enable itself, allowing you to add an exception.
Another option: if you have the certificate listed on the servers list, click on the *accountserver line and delete it, and run through the [add exception] routine again.
Also note, to make it permanent there is a tickbox to do so at the time of adding the exception.
Hope that helps.
Arthur
Bear Dale
« Reply #160 on: September 30, 2019, 01:57:46 »
Try this:
Hope that helps.
Thanks Arthur for that detailed and terrific step by step walk through. It was like following a teaching aid and worked perfectly.
Thanks mate!!!!!
« Reply #161 on: September 30, 2019, 22:09:55 »
my Android tilted again, a new exception....
Bill De Jager
« Reply #162 on: September 30, 2019, 22:42:37 »
Funny, I 'proceeded anyway' just once in Firefox yesterday and there have been no problems since.  No clearing of caches or anything of that sort.  Mystery...
« Reply #163 on: October 01, 2019, 17:53:54 »
Error.
« Reply #164 on: October 01, 2019, 18:08:16 »
error
