Author Topic: New-Nikkor 135/2!!!  (Read 17801 times)
New-Nikkor 135/2!!!
« on: July 21, 2019, 05:24:30 »
https://richardhaw.com/2019/07/21/repair-new-nikkor-135mm-f-2/
I love this lens a lot!  :o :o :o
chromatic aberration seems a bit high but it can be avoided, mostly. ::)
Re: New-Nikkor 135/2!!!
« Reply #1 on: July 21, 2019, 10:58:43 »
To be precise, yours is the AI 135mm f/2 :) :o
« Reply #2 on: July 21, 2019, 11:01:40 »
The ser. No. 179161 suggests that it could be one of the very late K version converted with the appropriate Ai kit.  According to your website.  ::)
« Reply #3 on: July 21, 2019, 11:46:19 »
One heavy beast! ;)
« Reply #4 on: July 21, 2019, 13:27:49 »
Richard, your reviews are a good read - very informative, as they try to capture the characteristics of lenses (and illustrate them), instead of providing pure "metrics".
Lots of good sample shots too.
Also, nice picture by Fons, wide-open I guess. The blur circles look perfectly smooth, which explains in part the quality of the bokeh.
« Reply #5 on: July 21, 2019, 13:30:18 »
Wide open, indeed Airy.
« Reply #6 on: July 21, 2019, 15:44:15 »
yes, as Akira said. it's K according to your amazing site  :o :o :o
another collector pointed out that this is the rarest one since K weren't made in large numbers ::)
« Reply #7 on: July 21, 2019, 15:45:18 »
nice photo!  :o :o :o
i can see some chromatic aberration but i guess thats the signature of this lens.
« Reply #8 on: July 21, 2019, 22:15:26 »
You are absolutely right! However it is AI, not an AI converted "New Nikkor" (K).  It is not the first time I have seen native AI lenses with K serial numbers.
- the focus grip is like an AI lens, the grip on the K version is more finely divided, and slightly darker/glossier
- it has the maximum aperture index post, at about 6:30 o'clock on this image. Only AI lenses have this:
« Reply #9 on: July 21, 2019, 23:21:11 »
Roland, thank you for the details.  If I understand correctly, the function of the aperture index post is rather an afterthought.  It was originally added to the aperture ring to interlock with the EE control unit DS-12 for F2AS.
« Reply #10 on: July 22, 2019, 00:27:54 »
The Maximum Aperture Indexing post is not the small tab on the aperture ring which engages the EE control unit for the DS-12. The Maximum Aperture Indexing Post is part of the rear lens protector - on the picture above it is the part which sticks out just above the circled screw at the bottom.
On pre-AI lenses the rear protector is often a simple rim which goes 360° around the rear element. On some lenses the lower section is higher for extra protection.
On AI lenses (including AI-S, AF) the rear protector only covers the top half of the lens, with a short post on the bottom half somewhere around 6:00 - 6:30 o'clock. The precise position of this tab signals the lens maximum aperture to certain cameras which have a feeler at the bottom of the mirror box. The Nikon FA uses this to determine the lens maximum aperture, needed for matrix metering. Other cameras from the same period used it for flash metering. Only a handful of cameras use this feature.
The maximum aperture indexing post is the sure way to know the lens is native AI and not AI converted.
« Reply #11 on: July 22, 2019, 00:33:40 »
Now I remember that.  Thank you, again, for the detail!
Gerhard2006
« Reply #12 on: July 22, 2019, 00:35:08 »
Glad to see you finally got this lens, I asked you about a couple of years ago and you said it was on your radar as a highly valued acquisition and it appears your copy is also almost mint. I have the Ais version and I love it as well. It is a bokeh machine as Fons horse picture testifies. I notice the helicoid threads on yours was very clean. My focussing is really stiff, was yours also or is it just because the lens body is so heavy?  Thanks in advance, Gerry
« Reply #13 on: July 22, 2019, 00:52:45 »
maybe this is a franken lens :o :o :o
« Reply #14 on: July 22, 2019, 00:54:19 »
hello!
the focus shouldnt be stiff, but the focus throw should be quite long :o :o :o
it needs to be serviced probably.
