Author Topic: Poor man's gimbal  (Read 8444 times)
Matthew Currie
Poor man's gimbal
« on: June 28, 2019, 03:03:38 »
Every once in a blue moon I wish I had a gimbal for a big lens.  The 200-500 is pretty good hand held but it gets tiring when lurking for birds.
Did you ever notice how much the arm of a Wimberly Sidekick resembles the leg of a mountain bike fork?  I did.
This is definitely a shade-tree project, booger welded out of left over bicycle parts, assorted hardware, a clamp that I broke running over it, and a pad that I made that didn't come out right, but it balances and it works.
Re: Poor man's gimbal
« Reply #1 on: June 28, 2019, 05:21:33 »
Well done - a nice repurposing of the bike parts.  Necessity is the mother of invention as they say.   :)
Netr
« Reply #2 on: June 28, 2019, 05:22:06 »
Well done.  Looks good.
PeterN
« Reply #3 on: June 28, 2019, 07:30:28 »
Clever re-use!
Peter
« Reply #4 on: June 28, 2019, 09:03:06 »
Looks so neat that I didn't understand what you were talking about at first.  Amazing job!
Randy Stout
« Reply #5 on: June 28, 2019, 14:59:09 »
Matt:
You would have to call this Yankee ingenuity !  How smooth is the action/movement?
Nice job.
Randy
Matthew Currie
« Reply #6 on: June 28, 2019, 15:55:41 »
Matt:
Nice job.
Randy
It's pretty smooth.  The top portion is made from a cut down steel bicycle hub, with a cup and cone ball bearing at the lens end, and a bronze bushing at the other.  The axle is just a 3/8 inch bolt, and tension is achieved by tightening the clamp as a nut.
When I ran over my tripod a couple of years ago, and broke the clamp on the ballhead, I rethreaded it, and it now has a stud whose hole goes all the way through to the 3/8 inch mounting stud.  So once the drag is right, I can sock down that stud, and lock it in place.
It all would have been neater if I'd been able to weld aluminum, and if I weren't so farsighted that my welding is often in the wrong place, and ends  up pretty messy.  I used a Mig welder, but in retrospect I probably should have brazed it.
Randy Stout
« Reply #7 on: June 28, 2019, 18:33:54 »
Matt:
thanks for the additional info!  Perhaps a tig welder in your future?  Very clean and pretty welds, if a bit fiddly to learn.
Depending on your RX, and how much astigmatism you have, often a simple pair of readers can be used under your hood for easier close up work.
Cheers
Randy
Matthew Currie
« Reply #8 on: June 28, 2019, 20:37:04 »
Matt:
Cheers
Randy
Indeed, readers under the hood do help, but I was lazy and the ones I was using in the shop were not very good.  I welded outside in the sun, and well, excuse after excuse....
Unfortunately, one thing I cannot correct is fine distance judgment.  A very nasty bicycle accident broke my trochlear nerve, so although my eyes work not so badly, and I have partial binocular vision at distance, up close I see double, and my eyeballs are tilted relative to each other, which is not correctable,  so close welding is a bit of a gamble.  For bigger stuff, I find it much easier to stick weld with a "drag rod."  My bead may wander, but I'm not quite so likely to be welding the sky.
FredCrowBear
  • Frederick V. Ramsey
« Reply #9 on: June 29, 2019, 04:20:49 »
+1
Frederick V. Ramsey
Steven Paulsen
  • Cumpulsive Tinkerer
« Reply #10 on: July 23, 2019, 22:35:32 »
Instead of calling it a Sidekick, using bicycle parts.......You made a "KickStand."
(Is that a Bogen/Manfrotto 3001/190 on the bottom?)
Matthew Currie
« Reply #11 on: July 24, 2019, 01:20:20 »
It's a Bogen 3021 Bpro, which I bought at a yard sale a few years ago for $12 along with a 3029 three way head and spike feet and an L bracket and an added video tilting column.  Oddly enough, I did not dicker over that one.
The Kirk ballhead is a later addition.
