Author Topic: Rocket Science - Poker Flat Research Range  (Read 21698 times)
« on: March 22, 2019, 07:49:03 »
That is Science with rockets. Poker Flat Research Range north of Fairbanks is one of 3 facilities on the northern hemisphere capable of sending up sounding (measurement) rockets used to study aurora and the upper atmosphere. The two other facilities are located at Andøya in Northern Norway and in the Ny Ålesund research community in Svalbard. Poker Flat Research Range recently celebrated its 50 year anniversary and offered a unique opportunity to visit the upper research facilities located 5 miles  at the top of a hill from the rocket shooting range - they are off limits on regular tours in summer. A lot of other people (more than expected) thought it was a great opportunity, and the organizers had to scramble to provide enough shuttles. The line was very long, but temperatures were slightly above freezing so the wait was fairly comfortable. I used the opportunity to test my new D500 at ISO 25600. High ISO noise reduction was set to low, but even that setting still kicks in pretty hard in CNX-D at this high ISO. Otherwise I mostly used ISO 6400 for the other handheld shots.
During the wait there was also entertainment with demonstration of weather balloon launch. In the foreground is the cradle for a sounding rocket.
All sky cameras have for a long time been important instruments in the aurora research. In the foreground is shown an ancient film based model based on mirrors. The modified film camera was used for time lapse photography in the box below. In the background is the Nikon 8 mm lens used these days mounted on a Sony body. Also there is a CMOS camera on the bench, and a smaller fisheye lens that was not mounted. Of course I found it proper to capture my image with the Nikon 10.5mm fisheye.  :)
#3
Due to the long wait it was only time to visit one of the other two facilities on top of the hill. I went for the LIDAR facility. This powerful pulsed laser beam is used to measure the composition of the atmosphere in a fashion similar to how a sonar is used underwater. The powerful laser cannon is located in the basement and the beam directed up to the dome though a system of optical benches and mirrors.
#4
Smoke was used to visualize the beam.
#5
Btw. next day I read on the front page of DPR how lasers used to remove tattoos had damaged a camera sensor just by the reflections from tissue - GULP. My D500 sensor still seems intact though.
Powerful beam in the sky. We were allowed to operate the beam on the computer - pretty cool.
#6
Some of the antennas used to download real time telemetry from the rockets and also radars used for the sky is also shown, but I did not make it to that facility.
Down at the launch pads, the Block House is where all the information from the instruments are applied to evaluate how favorable the night sky conditions are for an experiment, and control the sounding rocket launch. It is a crappy image, but i thought the other name of the building would be appreciated by someone here.  ;)
#7
Here are the panels used to control the individual rockets. The camera to the left is pointing to one of the key switches used to manually control the launch. The countdown can be interrupted down to the very last second. It was said that making the decision and controlling that switch was likely the most stressful task a scientist could do. Most of us used to photograph the aurora know how unpredictable it can be, and the person in charge of this switch has to make an informed decision trying to predict how good the aurora will be 20 minutes in advance (that is how long the rocket takes to reach measurement altitude). A rocket launch itself costs about $1 million, but the payload carried on the rocket costs much much more and cannot be reused without a complete rebuild.
#8
The panels look surprisingly traditional with respect to the level of technology, however here it is the true and tested technology that counts, not the latest and  less tested one.
On to the launch pad itself, we were informed that we were not allowed to photograph the launch ramp according to US federal regulations, however we were encouraged to photograph the sounding rocket by framing low, so that we did not include the launch ramp above in the image. It was said that there is no such thing as a standardized rocket in use. Just about every one is different dependent on the actual experiment of each study.
#9
#10
A closer look at the tip where the payload is located.
#11
Finally a look at a couple of payloads that were recovered after a launch.
#12
Re: Rocket Science - Poker Flat Research Range
« Reply #1 on: March 22, 2019, 08:12:23 »
Thanks Øivind for sharing, interesting.
« Reply #2 on: March 22, 2019, 10:03:05 »
Thanks for the comment Bent, glad you liked it.
« Reply #3 on: March 22, 2019, 11:15:20 »
 #7 my place? gosh. a long way to get there. Thank you for the documentation!
« Reply #4 on: March 22, 2019, 11:40:57 »
;D ;D
BW
    • Børge Wahl-Photography
« Reply #5 on: March 22, 2019, 12:27:51 »
Interesting! Knowing myself and how much fun I have launching rockets, I should never be in charge of make decisions on weather to launch or not a million dollar rocket ;D I seem to have noticed a slight decrease in auroral activity this year compared to the last 4-5 years? It might have something to do with the massive cloud cover all winter, but still I have that feeling.
« Reply #6 on: March 22, 2019, 20:58:13 »
Thanks for commenting Børge. We are actually approaching a solar minimum now so that may be the reason. However this time around equinox tend to be more active than other times of the year. Too bad with the cloudy weather during the event, otherwise we could have gotten some nice displays at this rather dark location.
CS
« Reply #7 on: March 22, 2019, 22:01:19 »
Oivind, more good images from you. What lens(s) were you shooting with on your new D500 for this event?
Carl
« Reply #8 on: March 23, 2019, 02:32:03 »
This is an exciting report, Øivind!
A good place for Frank to bring his cooking tools while enjoying the visit.
« Reply #9 on: March 23, 2019, 03:17:44 »
Thanks Carl and Akira. The Nikon 12-24mm was used for all the displayed images except the 10.5mm fisheye one. I also used the fisheye for a few images at the LIDAR facility not displayed above. Here are a couple of them, the last one from the basement where the laser beam is deflected up to the dome room.
CS
« Reply #10 on: March 23, 2019, 05:49:02 »
Thanks, Oivind. I should mount my 12-24 on my D7200, it used to get exercise on my D200, and I always liked it. You have produced great results with it.
Carl
beryllium10
« Reply #11 on: March 23, 2019, 17:07:38 »
Øivind, these are great, I always enjoy science photos.  In addition to the geek stuff there's often a story in the backgrounds, like the old Yellow Pages off in the corner of the payloads photo (when did I last see one of those?) or the instructions written on the lid of the fisheye lens box. The Lidar photos really give you a sense of the power of the laser.  Of those I like the last one (second batch) best - the histogram must be interesting - saturated green, saturated red, zero blue.  Cheers,  John
Bill De Jager
« Reply #12 on: March 23, 2019, 19:53:25 »
Øivind, absolutely fascinating photos and discussion!
CS
« Reply #13 on: March 23, 2019, 20:36:39 »
To add another BTW, I just read that there's a danger to camera sensors from photographing self-driving vehicles. It seems they too use lasers that can damage your sensor. My question to that, and to which I've not seen an answer is, what about the danger of the laser being reflected back to the camera sensor? Is that a realistic concern?  :-\
Carl
« Reply #14 on: March 23, 2019, 22:35:58 »
Thanks for the kind comments all of you.
Carl, the 12-24mm is really one my workhorse lens besides the 300PF these days and is usually the one mounted on the D500. (The 300PF could have been so too, but I avoid having longer lenses attached during transport due to risk of damage from leveraged forces on the mount, for instance due to a fall while skiing).
The damage from the tatto removal laser was as I understand from the reflections (gulp again), not sure about the self driven car. I would think in both cases these were infrared lasers that might have been more difficult to detect and contain higher energies. The LIDAR facility also uses a red laser beam that did not appear to be active at the event. Here is an article describing the setup :  http://www.nict.go.jp/publication/shuppan/kihou-journal/journal-vol54no1.2/01-01B.pdf
beryllium10, I also appreciated some of those details, some of them missed by the eye at the time of the capture. For instance, in the same image of the payload, do I see a blood pressure cuff in the background? Perhaps the person launching the rockets need to have blood pressure monitored?  ::) Below I have a couple of more background images. I appreciated how they left everything as is during the event, and did not make any attempt at putting things in a order that should look nice. Science is usually not the ideal clean image of the equipment manufacturers web pages.
A working area at the LIDAR facility
The room where the laser sources (with yellow lines on them) are located.
Another view of the all sky cam, showing the clockwork driving it.
#3
