Author Topic: Having two bugs with PC-85  (Read 2117 times)
fentriss
« on: December 13, 2018, 21:52:19 »
The older Micro Nikkor PC-85 f2,8 lens here with the D800e collecting 2 walking bugs . (handheld, 3 external flashes used, tilted and shifted.)
Please show the original image here. 6,2MB! http://malus.exotica.org.uk/~zeg/bugs/DSC7626bugs2013c99.jpg
Re: Having two bugs with PC-85
« Reply #1 on: December 13, 2018, 23:09:33 »
Great detail on the full size image. The lighting is very contrasty. Did you us the tilt and shift to increase or decrease the depth of field?
Nikkor Shooter
« Reply #2 on: December 19, 2018, 20:00:36 »
Right. Called the Scheimpflug principle, the tilt could have increased the DoF.
The Scheimpflug principle is a geometric rule that describes the
orientation of the plane of focus of an optical system when the
lens plane is not parallel to the image plane. It is commonly applied
to the use of camera movements on a view camera. — Wikipedia.
fentriss
« Reply #3 on: December 19, 2018, 20:55:29 »
Hello Nikkor Shooter. It was very "tricky" to create any decent photo of those two walking bug's, those were always on the run. So i decided to have got a sharp area fixed with the eyes following the wandering friends in front. Than i tryed various combinations of tilting only, and together with shifting, propably it was all wrong, trial and error mode. There i have also had 2 flases installed. to have got some light on the foreground, and the "street" of the given bugs.  another shot from there. larger size 6mb.  http://malus.exotica.org.uk/~zeg/bugs/DSC7599bugs2013c99.JPG
bye bey, richard.
Nikkor Shooter
« Reply #4 on: December 19, 2018, 21:10:20 »
It was very "tricky"…
I understand, Richard. (BTW, the shift will not help with the DoF)
Since the tilt will, you have the chance to limit their movements
and follow them in that "extended" area.  8)
fentriss
« Reply #5 on: December 19, 2018, 21:43:44 »
Thats true! please have also in mind, there i have had the old PC-85 lens in use (still use it), after each orientation, where the bugs have gone too, i have had to open and close the aperture knob of that lens, together with d800e. bye bye. richard
