Author Topic: The Df Revival  (Read 97821 times)
Björn Carlén
  • Errare humanum est
    • flickr
Re: The Df Revival
« Reply #180 on: November 06, 2015, 22:54:27 »
T-Mount or T2 was an early interchangable mount system to connect lenses to different camera bodies.
Wiki here: https://en.wikipedia.org/wiki/T-mount
Interesting. A Tamron invention. T-2 was the Soligor version.
There is so much I don't know; but now a little less. Thanks!
Björn Carlén
Huddinge, Sweden
Re: The Df Revival
« Reply #181 on: November 09, 2015, 20:25:41 »
Just received the M42/Fmount today.
I was quite optimist when I said there is only 1 or 2 mm difference of thickness : there is actually 7 mm !
So, we can state that the T/T2 ring is a true 10mm extension ring... :D
Will try the M42 adapter tomorrow, if the weather is not too awful.
One more image with the Helios 58mm f/2.
Re: The Df Revival
« Reply #182 on: November 09, 2015, 22:16:27 »
I truly fall for these images :)
Re: The Df Revival
« Reply #183 on: November 10, 2015, 11:48:43 »
Thanks again, Jakov !
This last one posted was one of the first taken when I received this lens from Ukraine. ;)
John Harkus
Re: The Df Revival
« Reply #184 on: November 21, 2015, 12:13:28 »
Some quick ones with the "new" 50mm f/1.4 S-C, 1972 vintage, wide open on a PK-13 ring, more to follow when the weather improves!
Re: The Df Revival
« Reply #185 on: November 21, 2015, 12:40:32 »
Beautiful John.   It's a different lens than the AI and later models (the samples of AI/AIS I had were not very impressive).
Especially the center-sharpness is noticeable on the Pre-Ai versions. (and 'wild' bokeh and some nice vignetting as well)  ;)    I have the Nikkor S-Auto from 1968
John Harkus
Re: The Df Revival
« Reply #186 on: November 21, 2015, 12:43:34 »
Nice JG, and they look so right on the DF, bonus!
Re: The Df Revival
« Reply #187 on: November 21, 2015, 13:01:03 »
What the difference between the nikkor 50mm f/1,4 s-auto or s.c.-auto, coatings?
John Harkus
Re: The Df Revival
« Reply #188 on: November 21, 2015, 13:03:52 »
Yes, the S-C is multi-coated, gives a nice magenta sheen to the front element
Re: The Df Revival
« Reply #189 on: November 21, 2015, 14:50:40 »
The blue and yellow photo posted by John Harkus in #184 is great!
John Harkus
Re: The Df Revival
« Reply #190 on: November 22, 2015, 13:54:42 »
Some more from the "new" 50mm f/1.4 S-C this morning, bitingly sharp from f/2.8, and quite interesting at f/1.4. Not much I could do about the flat light though :(
Chimper
Re: The Df Revival
« Reply #191 on: November 24, 2015, 15:41:09 »
The little Df, although with the old 24-70, allowed a quick and quiet snap of this gentleman relaxing inside the National Building Museum, Washington DC.
iso 400, 1/30s, f4 @29mm.
RobOK
    • My gallery
Re: The Df Revival
« Reply #192 on: December 05, 2015, 16:01:05 »
Am going to holiday party tonight with the Df and a couple of primes -24,50 and 85.
Sometimes I've had trouble with low light focus, any tips?
I tend to shoot pretty open at dark events maybe f2.2?
I read about using the red focus aid on an SB-700 but not sure I want to.
My MF skills are not up to par I don't think (or at least my confidence at such)
Thanks
Rob
Re: The Df Revival
« Reply #193 on: December 05, 2015, 16:18:37 »
Rob, the other night Chris Dees and I were testing his Df against mine.
Chris has all the 1.4 lenses, but we concentrated on my Df and the 24/1.4.
Chris' Df did just fine with my 24/1.4.
Mine was horrible.
Chris had to set my AF fine tune Df default at -20, and additionally he set the lens to -20 and only then the lens was sharp.
Subsequently I sent my Df to NPS for servicing. It cannot be normal to push the AF fine tune to its maximum.
So I suggest you fine tune the DF and the lenses prior to the party.
RobOK
    • My gallery
Re: The Df Revival
« Reply #194 on: December 05, 2015, 17:08:18 »
A good practice for sure... for my lenses for tonight, I don't have any concerns (i.e. have great results in normal lighting conditions), but I have only briefly done the fine tuning before.
Any thoughts on low light auto-focus?
